Which gear
Old Jul 31, 2011 | 03:40 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Default Which gear
I have an 87 A4 Dana 36 with some mods to intake, exhaust and motor. I currently have the 2.59 rear gear and was thinking of changing to the 3.07 but having a hard time finding that Ring&pinion gear. Anybody know of a good source or should I go to 3.54? Mainly do around town driving and a little highway driving.
Old Jul 31, 2011 | 05:24 PM
stevie1dr's Avatar
stevie1dr
Richmond Gear has ring and pinions for the Dana 36. If you select the 3.07 as I remember, you need a different casing. because of the thickness of the ring gear. The 3.54 and 3.73 will fit in the 2.59 case. I am currently running the 3.73 in my 89 and it is a monster out of the hole, but a bit hard on gas mileage. You'll probably want a good set of street radials or even slicks if you race it on the track. The 3.07 I tried was much snappier than the 2.59 and still got decent mileage. If you are going to do some serious racing (quarter mile or eighth mile, I would go for the 3.54 for the quarter, and 3.73 for the eighth.) I got mine from Randy's ring and pinion (as well as the install kit) up in Washington state.
Steve
Old Aug 1, 2011 | 04:11 PM
MotorCity_87_C4
Steve
I dont race, just want a bit more acceleration ability. Does Randy's sell the 3.07 gears or does anybody know where I can get a set?
Old Aug 1, 2011 | 05:47 PM
stevie1dr's Avatar
stevie1dr
You might contact randys ring and pinion. They show Dana 36 R & P sets but are only listing 3.54 and 3.73. Jegg's and Summit also have them in the same ratio but aren't showing a set in 3.07. You just missed on on this site posted today. I'll bet it was gone in less than an hour. I would still say to go with the 3.54 if you want some super street response. It isn't so wild as to kill your mileage a bunch and will give you a real SOTP rush!
Old Aug 1, 2011 | 06:19 PM
1963SS's Avatar
1963SS
I'm pretty sure my 95 has the 3.08 from the factory. It is an option right?
TA's Avatar
TA
Its been pretty well established here that the 3.07 ratio is optimal for an L98 car. Steeper than that will get you out of the hole a bit quicker, but wil hurt you after that. My 91, which sees a decent amount of track time, has had 2.59s, 3.07s, and finally a 3.33 ratio. The 3.33 offered me virtually no gain over the 3.07 and I'd probably go back to a 3.07 if I didn't already have a ton of $$ wrapped up in this one.
Another option for you is to buy an existing rear with a 3.07 in it and just swap them out. You can easily do this by yourself in your garage in an afternoon and it'll probaby be the cheaper route. They come up for sale here fairly often. Just saw this one today.
http://forums.corvetteforum.com/c4-p...dana-36-a.html
Old Aug 1, 2011 | 08:20 PM
rodj's Avatar
rodj
Buy the time you buy new gears ( D36 gearsets are very expensive ) and pay install costs is the cheaper option.
You have to remove the batwing / head assembly anyway to do the gear swap.
Old Aug 1, 2011 | 09:41 PM
MotorCity_87_C4
I was planning on doing the U joints this winter, and thought that while I was there may as well do the gear.
Old Aug 1, 2011 | 09:59 PM
88BlackZ-51's Avatar
88BlackZ-51
I would listen to TA. He knows his stuff with the L-98's and what works.
Old Aug 1, 2011 | 10:35 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
They are correct, if you go to a 307 you have to change the casing also drive shaft and so on. After this racing season I'll be putting 3:73's in my D36.
Old Aug 2, 2011 | 12:18 AM
rodj's Avatar
rodj
Only need to change the DS if doing a D44 swap.
D44 is a bolt in swap using ALL D36 suspension parts except DS and C-Beam
Even they can be modified to fit a D44
Old Aug 2, 2011 | 09:42 AM
kimmer's Avatar
kimmer
Old Aug 2, 2011 | 10:05 AM
Rodney_Gold's Avatar
Rodney_Gold
I changed to a 3.54 , almost no mods barring a set of headers on my 86 , cost me around $1000 for gears and installation , it's a totally different car ...smokes the tyres and shoots out the hole , top speed is around 225kph. You can feel the effects of a 3.54 vs 2.59 at the top end by just leaving your car in D and not in OD. Basically its the same as having only D but with 4 gears and a wicked 1st , 1st to 2nd gear will also smoke the tyres and 3-4th will twitch the back on WOT shifts. Best money I ever spent on my vette...cheapest seat of the pants "power increase" too. The 3.54;s are not over the top , no uncontrolled wheelspin , tho in the wet , the car is a bit of a handful when acclerating form a dead stop if you try being a little enthusiastic. Not sure why GM put in the 2.59 , stupid gear for a sports or performance car - makes it embarrasingly slow compared to modern hot hatches ..
Old Aug 2, 2011 | 10:28 AM
rodj's Avatar
rodj
Originally Posted by Rodney_Gold
Not sure why GM put in the 2.59 , stupid gear for a sports or performance car - .
For CAFE (Corporate Average Fuel Economy)
"If the average fuel economy of a manufacturer's annual fleet of car and/or truck production falls below the defined standard, the manufacturer must pay a penalty"
so the better fuel economy of the 2.59 gears helped raise GM's average MPG
Old Aug 2, 2011 | 11:40 AM
Rodney_Gold
Yes , typical bean counter corporate response , just ruin the car with a measure to save a bit of boodle, cost me $1000 to "fix"....absolutely idiotic , Ferrari , lambo, Porsche et al would NEVER consider doing that or compromising performance..if you want economy , buy a honda jazz/fit like my wife drives...
Old Aug 5, 2011 | 10:57 PM
MotorCity_87_C4
Looks like a forum sponsor IKERDS carries rebuilt pumpkins and complete rear suspensions and you can pick the gear you want. Anybody have feedback on this vendor?
Old Aug 7, 2011 | 04:08 PM
MotorCity_87_C4
Found somebody within a 2hrs drive with a 3.07 Dana 36 for sale. Just got it home. Looks like I'll be busy with a winter project.
Old Aug 8, 2011 | 09:25 PM
l98tpi's Avatar
l98tpi
Max G’s
[QUOTE=TA;1578292151]Its been pretty well established here that the 3.07 ratio is optimal for an L98 car. Steeper than that will get you out of the hole a bit quicker, but wil hurt you after that. My 91, which sees a decent amount of track time, has had 2.59s, 3.07s, and finally a 3.33 ratio. The 3.33 offered me virtually no gain over the 3.07 and I'd probably go back to a 3.07 if I didn't already have a ton of $$ wrapped up in this one.
After thorough investigation of changing to deeper reduction rear gear with L98, Auto, 3.07, and 315/35 17's I have concluded that jsut as TA said that the 3.07 is optimal for the power band of the L98 and or similar intake. If you were to go to a 3.54 or 3.73, you will have to go to 4th gear (overdrive) to stay in the power band when running 1/4mile or going down long straight on the track. Likewise, my primary application is autox and if I moved to 3.54 or 3.73 I would have to utilize 3rd gear sometimes. As well, having to upshift to a higher gear may cost "overall gear reduction" even if in the power band. There is a lot of factors to consider when picking the optimum gear.
To Which gear
