how do i remove my entire door?
Old Jul 31, 2011 | 04:04 PM
rithsleeper's Avatar
rithsleeper
Default how do i remove my entire door?
I see the bolts but its the wires... one would think there would be a connector at the hinge but I don't see it. I am painting and the door came out crap so I want to be able to set it on horses to get a good spray.
Seems easier to cut the wires and then re connect them, than to pull them all out and attempt to pull through with a clothes hanger.
Is there a easy way to remove the outside panel to paint it?
Old Jul 31, 2011 | 04:42 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I took the inner door panel off and disconnected everything & pulled the wires/connectors out of the door. BUT, I was replacing the entire interior after the car was painted, plus I was going from metallic gray to black so the inner jams had to be painted too. If you want it done right you'll have to do the same.
Old Jul 31, 2011 | 04:52 PM
rithsleeper
Well s*&t... thanks, here we go....
Old Jul 31, 2011 | 08:18 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
sawzall comes to mind................
Old Jul 31, 2011 | 08:36 PM
jeffp1167's Avatar
jeffp1167
Sawzall requires to much work, just leave door open and backup into something and the door will come right off.
I feel your pain though, I replaced both doors on my 90 and had to remove all the wiring from the doors before they could be unbolted it's not really that hard though just take your time.
Old Jul 31, 2011 | 08:58 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
or a good acetylene torch.
Old Jul 31, 2011 | 09:31 PM
JackDidley's Avatar
JackDidley
Its not that hard. Take off the interior panel, reach in and unplug everything. Just pay attention to the routing.
Old Jul 31, 2011 | 09:33 PM
coupeguy2001
rithsleeper, you don't know jack.
Jack, ,meet rith, Rith, meet jack
Old Jul 31, 2011 | 09:38 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
To how do i remove my entire door?
