OK, I have replaced the Fuel Pump, Fuel Filter, and the relay. Finally got the car to start and run. When I took it for a ride it ran great, until I punched it. When I got it up to around 70 it was running great, when I slowed down the car felt like it had a clogged cat. Now every time I drive it I hit the gas and the car will not get over 30 mph, and the idle is rough as hell.............................HELP
I'm interested in this too since my car is doing the same thing (Iroc 350TPI). I replaced the pump, and now my car surges and runs really lean at idle. I checked my fuel pressure and while running, im at 30PSI, but its steady. I tried another regulator from a buddy which is a known good regulator, but got the same PSI. I put a quarter on top of the regulator, and boosted the "priming" fuel pressure to 46 (was 40 at prime previously). I have to put the plenum back on, and see if it fixes my problem. I don't know if that would help at all, but check your fuel pressure at the rail and tell us what you get.
I also have a suspicion that my injectors may have a small leak since it drops 6psi in 30 minutes (with out the quarter in there) and 15PSI in 20 Minutes (with the quarter in there)
You can check to see if the MAF is causing problems by unplugging the MAF cable. The car will run fine without it.
This problem seems more like a fuel pump problem to me. I had symptoms similar to this when the pickup sock rubbed against the bottom of the tank and shredded. The pump sucked up the fibers and the engine would run, but not well.
It might be the wrong pump or a problem with the pressure blowoff in the pump. You need to check fuel pressure at the rail to find out what's going on.
Timing?, Injectors ?, bad gas ?. When my `87 ran like crap, it turned out to be the MAF.
I had this same situation happen to me and it turned out to be timing. Since the problem happened when you jumped on the gas, I'd say it's a likely culprit. The "fork" that holds down the distributor wasn't completely tight and it rotated when there was heavy power on the cam. It's also the easiest thing to check. All you need is a timing light.
A ripped Diaphram would cause the engine to run very rich and lose power. Remove the fuel pressure regulator vacuum line and see if fuel is present. If there is, replace the diaphram.
