84 engine serpentine bracket assembly picture needed
Old Aug 1, 2011 | 04:07 AM
jeffp1167's Avatar
jeffp1167
Default 84 engine serpentine bracket assembly picture needed
anyone have a pic from a 84 assembly manual they can post? Stumped at where reinforement braces go on drivers side and ho the smog pump attaches on the bottom.
Old Aug 1, 2011 | 07:48 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Here is an actual photo of an 84 belt if that is of any use
Old Aug 1, 2011 | 07:51 AM
jeffp1167's Avatar
jeffp1167
Thanks but I need to see how the bottom braket is mounted that holds the bottom of the smog pump.
Old Aug 1, 2011 | 08:11 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
My smog pump is gone so I can't get a picture of that. Do have a picture of the smog delete pulley though:
Old Aug 1, 2011 | 08:27 AM
jeffp1167's Avatar
jeffp1167
I need smog pump though, california car.
Old Aug 1, 2011 | 08:39 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Smog pump brackets and mountings should be the same as that used in the delete arrangement shown.
Old Aug 1, 2011 | 03:59 PM
jeffp1167's Avatar
jeffp1167
Ok so I have 3 left over brakets, these two in this picture. one appears to be a power steering pump bracket and the other a smog pump lower bracket like my 90 vette has. However this smogpump bracket will not mount to the 84 smog pump, so this can't be what I need.
I then found this bracket and I'm curious if this could be what is used as well as what else I am missing.
Old Aug 1, 2011 | 04:55 PM
jeffp1167's Avatar
jeffp1167
I am assuming this was the missing bracket and a long bolt passes through it and the pump and into the intake manifold. Is this correct?
Old Aug 1, 2011 | 05:50 PM
jeffp1167's Avatar
jeffp1167
Think I got it all sorted out now thanks. Still need pics of how the reinforcement braces went on the alternator/smog pump and power steering pump though
Old Aug 1, 2011 | 05:53 PM
jeffp1167's Avatar
jeffp1167
BTW this is a 84 and 86 hybrid system which is why the a/c area and belt tensioner is different. Just didn't like the complexity of the 84 a/c brackets is all.
To 84 engine serpentine bracket assembly picture needed
