96 corvette speedometer
Old Aug 1, 2011 | 03:03 PM
cdreece's Avatar
cdreece
Default 96 corvette speedometer
what controls the speedometer on a 96 corvette.
have did lots of searchs but found nothing
my speedo stays a 0 when driving the tach works but not the speedo
any ideals where the hookups are grounds vacuums.....
Old Aug 1, 2011 | 08:16 PM
SJW's Avatar
SJW
The speedo is driven by the PCM, which counts pulses from the Vehicle Speed Sensor, which is driven by the output shaft on the transmission. I'd start by checking the connections at the VSS, and go from there.
Live well,
SJW
Old Aug 2, 2011 | 01:24 PM
cdreece's Avatar
cdreece
Thank You SJW checked the VSS and found a broken wire problem solved
Thank You Chris
Old Aug 2, 2011 | 09:27 PM
SJW's Avatar
SJW
Thank You Chris
It's always sweet when a fix is quick, easy, and inexpensive. It's also pretty rare. Congrats!
Live well,
SJW
To 96 corvette speedometer
