92 front spring removal
Old Aug 1, 2011 | 06:10 PM
C4vettrn's Avatar
C4vettrn
Default 92 front spring removal
If I remove the shock and lower ball joint so the bottom arm drops and the top arm can be held up. Will this give me enough room to get the spring out? The book calls for some spring compresor mechanism? Is this a must or is there a workaround? Thanks
Oh forgot to add all I am wanting is to install the lowering wedges.
Old Aug 1, 2011 | 08:11 PM
rodj's Avatar
rodj
Bottom arm won't drop much.
Needed leverage ( 2nd person with bar) to push against the bushes tension so it could be lowered out of way.
You need the front high in the air to allow the spring to arc down to the ground as you lever it out.
http://webpages.charter.net/khasting.../lowering.html
Old Aug 1, 2011 | 08:35 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I had mine on a lift and even then it was almost a two person job to get enough leverage to release it.
Old Aug 1, 2011 | 09:11 PM
jeffp1167's Avatar
jeffp1167
there is a metal bracket looking thing on each side of the car right bt the lower a-arm mounting points. if you remove these it makes it much easier to get the spring out.
Old Aug 2, 2011 | 10:26 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
I forgot about that splash/debris deflector - remove it first.
Old Aug 2, 2011 | 11:10 AM
C4vettrn's Avatar
C4vettrn
Can the rubber bumpers on the end of the springs be removed for some added drop without any adverse effects?
To 92 front spring removal
