BOV / bypass valve question
Old Apr 27, 2002 | 07:05 PM
rerquiredtext's Avatar
rerquiredtext
Default BOV / bypass valve question
I was wondering if it is possible to get that whistling sound that you get with a turbo ( when the air is being vented) with a supercharger?
Old Apr 28, 2002 | 03:11 PM
steveelsbury's Avatar
steveelsbury
Default Re: BOV / bypass valve question (rerquiredtext)
My engine rebuild has left me with no AIR or EGR system, so I've decided not to bother with a recirculating dump valve on the blower any more. Intending to fit a standard, piston-type dump valve that just vents to air - that should make a nice whistling whoosh when I back off the throttle!
:cool:
Old Apr 29, 2002 | 01:34 PM
XTwinTurbo's Avatar
XTwinTurbo
Yes, it's possible.
As long as your talking about the air release sound between shifts you can change out the stock recirculating valve on the Supercharger for a blow off valve. I have done exactly that using a HKS SSBOV with some custom tubing.
As a side note though, some people claim that by dumping the excess air into the atmosphere instead of recirculating it back into the intake, you will cause the motor to run rich between shifts. This is because the metered air is not the same volume as the air ingested into the motor. So far this has not been a problem for me but if you're building up a race motor you may have a difficult time tuning all variables.
Old Apr 29, 2002 | 10:34 PM
Janaelen's Avatar
Janaelen
Default Re: BOV / bypass valve question (XTwinTurbo)
XTwinTurbo,
This would only be the case for MAF cars not MAP cars correct?
Old Apr 30, 2002 | 03:31 PM
XTwinTurbo's Avatar
XTwinTurbo
Default Re: BOV / bypass valve question (Janaelen)
XTwinTurbo,
This would only be the case for MAF cars not MAP cars correct?[/QUOTE]
You may be correct on this. I actually don't know any other effects besides it has no impact on my '94. I believe the '94's run a MAP sensor instead of MAF.
Old May 8, 2002 | 05:50 AM
gcrouse's Avatar
gcrouse
Excess boost pressure can dump to the atmosphere if it hasn't been measured yet; i.e. MAP or a blow-thru MAF (downstream of the BOV).
The only time the dumped air needs to recirculate is if it's already been measured; i.e. draw-thru MAF, MAF upstream of the BOV.
To BOV / bypass valve question
