Replacing Fuel Tank 88 Vert
Old Aug 2, 2011 | 11:20 PM
Tony A.'s Avatar
Tony A.
Default Replacing Fuel Tank 88 Vert
Need help fellas...if I opt to replace my fuel tank on my 88 vert, can it be taken out without removing the entire rearend of the car?
And, any vendors sell NOS or reproduction tanks at a reasonable price?
Old Aug 3, 2011 | 12:23 AM
oldalaskaman's Avatar
oldalaskaman
no , and several discount suppliers on the net
Old Aug 3, 2011 | 03:04 AM
rodj's Avatar
rodj
http://www.corvetterecycling.com/pro...4190004001.htm
Is listed as 'for 89+ but no noticeable difference between my '87 and '90 tanks
NB;
the sending unit alone is worth $200 (without the pump).
http://www.corvetterecycling.com/198...p/25027510.htm
Could always sell those to recover some of your outlay
Old Aug 3, 2011 | 02:31 PM
3D87C4's Avatar
3D87C4
I don't have any of my Vette books with me, sorry if this is redundant due to the previous post. If I recall correctly, the later year tanks are partitioned/divided to prevent fuel starvation due to sloshing in a turn. If I were replacing my tank I'd want to take advantage of this if possible. Anyone know when this change occured and whether the newer tank can be mounted in the OP's car? (or my '87 for future reference)
Old Aug 4, 2011 | 12:41 AM
383vett's Avatar
383vett
There are two ways to get the C4 tank out; 1, remove the rear bumper fascia, 2, sawzall.
Old Aug 4, 2011 | 01:26 AM
87 vette 81 big girl's Avatar
Showing off that Solid Axle 12- bolt Chevy rearend again Will...........
There is no way a C6 rear independent setup can take the abuse you dish out in your 1984 drag race Vette.
I just can not see it lasting forever Will.
12- bolt you have YES.
Thanks for the photos in the past.
You are the #1 reason why I am installing my 1957 Pontiac rear into my '87 Vert.
Brian
Old Aug 4, 2011 | 10:38 AM
383vett's Avatar
383vett
Brian
Keep us posted, Brian. Willie
To Replacing Fuel Tank 88 Vert
