Timing light?
Old Aug 3, 2011 | 09:57 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Timing light?
What model timing light are you guys using ? What make/model would you recommend ?
Old Aug 4, 2011 | 07:53 AM
joe paco's Avatar
joe paco
got the $40 model at autozone, didn't think I needed the digital one. I had a Penske-Craftsman for 40 years and it still worked, but gave it away a year before I bought the 91.
I will use if a half dozen times. Better to borrow or rent one, but could not locate one. it is lightweight, induction pickup, and looks like a Star Trek stunner.
joe
Old Aug 4, 2011 | 10:42 AM
active1951's Avatar
active1951
I think I got mine at a auto parts store when I had a C3. Still use it for prelimenary spark checking. Anything with a battery hookup and a clamp to fit over plug wire is fine for me.
I remember the primitive old style w/o battery hookup and you had to put it inline with plug and boot. Those good ole bad days......
Old Aug 4, 2011 | 11:22 AM
1991Z07's Avatar
1991Z07
I have an old Craftsman one that has electronic spark advance on it. Dial in how much you want and set the car at what "appears" to be zero/TDC.
Takes all the variances out of the degree markers...pretty accurate that way.
Old Aug 5, 2011 | 12:04 AM
87 vette 81 big girl's Avatar
Snap On 1261 Digital Advance Timing light is what I own & use.
I have owned it since 1991.
Still works like new & never has failed me.
Costed me around $250 back then.
Same model made yet today in more modern casing for $400.00
Snap On 1261 Timing light is the standard of all Pro engine builders & veteran racers around the world.
Dead On accurate.
I take good care of mine like a fine C4 Corvette.
BR
Old Aug 5, 2011 | 06:10 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I use a Craftsman also with the electronic advance feature, I retired an old Sun that I had bought many years ago when the name Sun still meant something. I really like the Craftsman, I've had it now just over a year.
I remember the old ones mentioned where you had to put an adapter between the spark plug & the wire, you couldn't see the beam in a well lit garage and forget using it outside unless it was night time.
Old Aug 5, 2011 | 08:48 AM
93VettePilot's Avatar
93VettePilot
Has anyone come up with a good pointer to take the readings from the front hub?
Old Aug 5, 2011 | 09:22 AM
Midnight 85
I always paint the timing groove on my balancers white, then put a small dot or stripe on the tab right on the degree mark I set it to. Makes life a lot easier.
Old Aug 7, 2011 | 04:37 AM
93VettePilot
Mine is a different animal. It is an LT1 with rear mount distributor I don't have any pointer on my LT1 engine. Was trying to come up with a good, inexpensive pointer so I could check the computers timing against actual.
To Timing light?
