Need PIC's 86 Vert decklid cable setup
Old Aug 7, 2011 | 06:10 PM
3D-Aircrew's Avatar
3D-Aircrew
Default Need PIC's 86 Vert decklid cable setup
Mine has been modified ... rigged. Need pictures of the rear decklid release cables and attach points.
Thanks in advance
Old Aug 8, 2011 | 07:14 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Thanks in advance
Are you talking about the decklid itself or the #5 bow. The cables for decklid release are the emergency release cables used in the event of solenoid failure and attach straight to the latch mechanism. The #5 bow uses the lever and cables as the only method of release. Which do you need. I can have the pics up today.
Old Aug 8, 2011 | 08:42 AM
3D-Aircrew's Avatar
3D-Aircrew
"The #5 bow uses the lever and cables as the only method of release." That's what I need thanks so much.
Old Aug 8, 2011 | 10:19 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Just snapped these off. Sorry that many are blurry, but I was in a hurry. If you can tell from these what you need more detail on, I can get some better pics for you.
You probably already have this as it's from the FSM and isn't much help, but her it is anyway:
Old Aug 8, 2011 | 11:21 AM
3D-Aircrew's Avatar
3D-Aircrew
Your're the best! Thanks
Old Aug 8, 2011 | 01:13 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
No perspiration. Just let me know if you need any clearer shots.
To Need PIC's 86 Vert decklid cable setup
