car won't start after parking
Old Aug 11, 2011 | 03:03 PM
eandmy's Avatar
eandmy
Default car won't start after parking
car 1990 l98 vet car runs great go on ride stop and park back in car wont start temp normal not hot, no sound to starter, after about a 1/2 hour starts up what could be the problem? help eandmy
Old Aug 11, 2011 | 08:39 PM
MissileDoc's Avatar
MissileDoc
Try cleaning and tightening your battery cable connections on both ends of each cable. If that doesn't fix the problem, I would check the starter soleniod connections on the starter itself.
Old Aug 11, 2011 | 10:49 PM
jfb's Avatar
jfb
Might be VATS. You do diagnosis when the problem occurs. Measure the voltage on the clutch safety switch (gear selector sw at base of gear shift if automatic) and see if there is 12v in crank position. Unplug and jump the clutch safety sw with at least a #14 wire and measure the voltage on the jumper and see if it will crank. If no 12v and the clutch sw is ok, then remove the panel above the drivers feet and find the two wires from above the steering column and unplug them. Insert key and measure the resistance across the wires, it should measure the same as the key pellet. More than 4% error and VATS won't allow a crank. Wipe the pellet with electrical contact cleaner and spray a short pulse of cleaner into the key lock and try a crank. If no crank, connect a resistor the same value as your pellet across the 2 socket pins from the wiring harness (simulates key in ign) and try a crank. If it cranks, you have a worn ign lock and a new lock will have new contacts in it that make connection to the pellet. Let us know what you find as diagnosis may need to go further.
Old Aug 12, 2011 | 12:23 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
I used to have that problem all the time when I was younger and out on a hot date. "Sorry Bambi, we'll have to stay here a while longer. What should we do while we wait?"
Old Aug 12, 2011 | 11:03 AM
eandmy's Avatar
eandmy
Default car wont start for 1/2 hour after parking
i appreciate the fix but if it was elect.problem does it heal itself in a half hour all the wires are secure battery is strong this is a mind boggler eandmy
Old Aug 12, 2011 | 12:59 PM
eandmy's Avatar
eandmy
Default wont start
ok guys just went to start car sat all night, wont start there goes the heat theory, battery strong, no sound from starter now what? is it possible the computer is bad? eandmy
Old Aug 12, 2011 | 01:41 PM
navy_vette's Avatar
navy_vette
We definately need to know if it's VATS or not. It is generally going to be that or a safety switch. There are 2 safety switches. One on the shifter and one behind the brake pedal.
JFB posted procedures above.
Old Aug 12, 2011 | 02:22 PM
eandmy's Avatar
eandmy
Default jfb
thanks but i don't know what the vats are? eandmy
Old Aug 12, 2011 | 02:50 PM
3D-Aircrew's Avatar
3D-Aircrew
Forum search is your friend ... VATS
To car won't start after parking
