air pump elimanator
Old Apr 28, 2002 | 08:37 PM
dave g's Avatar
dave g
Default air pump elimanator
when you remove the pump what do you do with all the electric valves that are there in the front off the motor its a 86 . just want to know if the check engine light will come on if there disconected.
Old Apr 28, 2002 | 08:39 PM
Rob90's Avatar
Rob90
Default Re: air pump elimanator (dave g)
Get rid of them. No probs on my 90 :D
Old Apr 28, 2002 | 08:42 PM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Default Re: air pump elimanator (Rob90)
Trash
Old Apr 28, 2002 | 08:45 PM
Guest
Guest
Posts: n/a
Default Re: air pump elimanator (L98Terror)
i disconnected both of them as well as removed all smog and egr from mine, best thing ive done makes it so much easier to work on, ive done it to my 85 and 87, and no codes or problems yet............
Old Apr 29, 2002 | 12:42 AM
chucks88's Avatar
chucks88
Default Re: air pump elimanator (Kamarossrs)
No problems here either. I just haven't found a good spot to put the connectors that went to the smog pump.
Old Apr 29, 2002 | 12:49 AM
Vette9d1's Avatar
Vette9d1
Default Re: air pump elimanator (chucks88)
Is it true that taking off the pump might result in clogging of the cats after many miles? I remember hearing that somewhere... :confused:
Old Apr 29, 2002 | 10:29 AM
Oh My's Avatar
Oh My
Default Re: air pump elimanator (Vette9d1)
Then just get rid of the Cat! Until the EPA brings the price down about oh 100 % on cats, I'll just keep gutting them :blueangel:
To air pump elimanator
