Sticking throttle?
Old Aug 11, 2011 | 09:52 PM
Strick's Avatar
Strick
Default Sticking throttle?
Anybody have their throttle stick? Mine is sticking when I get off the gas after normal cruising at 60 mph or so. Feels like the cruise doesn't disengage, but it does. I have to kick the pedal down to get it to release back to idle. What do you think, throttle body needs cleaning? BTW, it's a 92 LT1 6spd vert.
Old Aug 11, 2011 | 11:40 PM
HlhnEast's Avatar
HlhnEast
Cleaning the TB couldnt hurt. Get some white lithium spray and squirt some into the throttle cable.
Old Aug 12, 2011 | 09:57 AM
WW7's Avatar
WW7
If lubing the shaft doesn't help,try moving the throttle shaft up and down to see if there"s any play ..When these TBs get older and well used they have a tendence to round out the hole the shaft passes through causing the shaft to bind.If this is the problem you can have the TB shaft rebushed so it works smoothly and doesn't bind....WW
Old Aug 12, 2011 | 10:13 AM
pmihaltian's Avatar
pmihaltian
Slingshot
In addition, put a drop or two of oil in the butterfly shaft on each side of the throttlebody. This light oiling eliminated my sticking throttle a couple of years ago.
Old Aug 12, 2011 | 10:51 AM
Strick's Avatar
Strick
Thanks guys. I'll try these ideas out.
To Sticking throttle?
