An elusive squeak
Just over two years ago I bought a reman 350 Vortec to replace the tired 305 in my '87 EC.
At the same time I put in a very mild Elgin Pro Stock cam. Since then I have had a squeak that is very irritating. It only squeaks at idle, 800-850 rpm. Just over idle it goes away, Also it doesn't do it until things get warmed up a bit. I have been all over this thing without finding it until I was working on it the other day, I loosened the distributor while the engine was running and the squeak stopped. If I tighten it back down the squeak returns. I ordered shims, they did no good, changed to a different distributor, no good. In order to keep the squeak silent I have to leave the distributor clamp loose and then the timing is all over. Has anyone ever encountered this? I won't even go into all I have done, you'd get tired of reading. Any ideas?
Sounds like the inner shaft is the key, not the outer shaft....how the gear mates and how the outer shaft pulls it down or against the gears...?
I think the lower housing bushing has rotated & is spinning freely inside of it.
No Press fit left.
You can remove the distrib. gear roll pin & remove the entire shaft & advance mechanism to verify this.
The lower bushing also may be micro- welded to main shaft.
I have seen both occurrences in the past.
BR
Look at the cam gear with a bright flashlight.
Make sure its A- OK.
Yeah,
With the roller camshaft you are supposed to use the special matching distributor drive gear.
It has a matching Rockwell hardness steel or cast iron gear so there no wear issues even after 100K miles.
Contact Elgin cams Monday if you have to.
I am thinking you can use a production GM distributor gear from a L-98 TPI engine.
No problem for you to obtain where you work at I know.
Its what keeps us mechanics.....solving problems.
