oil leaking
Old Aug 15, 2011 | 09:54 AM
ndanl's Avatar
ndanl
Default oil leaking
hello,
is it possible to leak oil from the distributor where it connects to the engine?
I have an oil leaking problem in the area where the oil presure sensor is and I cant figure out from where, the sensor is new and is not leaking ...
Old Aug 15, 2011 | 10:08 AM
oldalaskaman's Avatar
oldalaskaman
yes it is
Old Aug 15, 2011 | 10:23 AM
383vett's Avatar
383vett
There is a gasket between the distributor and the manifold. If torn or missing, that can cause a leak. More likely it is the area between the rear of the intake and the block that is leaking.
Old Aug 15, 2011 | 10:57 AM
ndanl's Avatar
ndanl
can you guys tell me which one is it from the corvettecentral.com or rockauto.com ?
they ship overseas
the car is 1991 corvette L98
383vett, yes in the rear of the intake area and I think that the gasket between the intake and the distributor is the only place that could leak from ... or do you have any other suggestions what else to check ? ?
thank you
Old Aug 15, 2011 | 12:15 PM
Deepa's Avatar
Deepa
there is a rtv'd area which seals the front and rear of the intake manifold to the block. this is probably where your leak is coming from.
Old Aug 15, 2011 | 12:26 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
they ship overseas
thank you
He means where the intake and the block meet at the rear. Most likely leak location. If you need the distributor gasket though, PM me an address and I'll post you one.
Old Aug 17, 2011 | 05:04 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
OK Dan, The gasket is on its way. Should be with you in a few days. I just stuck it in an envelope. Probably not your leak, but you'll be able to rule it out. Best of luck.
Old Aug 17, 2011 | 05:16 AM
mistaben's Avatar
mistaben
hello,
yes it is, but not likely. even if you didn't have a gasket there....
well at least on L98 series engines, if you didn't have a gasket there it would be not likely to cause an oil leak, though it wouldn't exactly be smart not too...
Old Aug 17, 2011 | 05:36 AM
ndanl's Avatar
ndanl
well if it steel leaks, can you advice which gasket is the one from between the intake and block ? ?
Old Aug 17, 2011 | 06:06 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Dan, I'm sorry I don't have a picture of the rear. I'll try to find one, but for now you can get a good idea of what we are talking about by looking at the front:
The horizontal line where the silver meets the black (intake meets the block) will have a seal. Should be RTV. The rear is the similar and where leaks usually start.
Old Aug 17, 2011 | 07:34 AM
ndanl's Avatar
ndanl
oook, so the seal should be RTV ? there is no special gasket or something ?
Old Aug 17, 2011 | 09:14 AM
Muffin's Avatar
Muffin
A rubber gasket, rather large thing actually, was used for years. Now all L98 builds use a large, 1/4 inch, bead of RTV or similar sealer.
To oil leaking
