flywheel as ereluctor wheel
I can't fault you for wishing to ditch the Opti. It has its weaknesses, but accuracy isn't one of them. The Opti, when functioning normally, delivers exceptionally accurate camshaft position, velocity and acceleration signals to the ECM/PCM.
The Opti would have been an ideal timing system, if it had used coilpacks rather than a distributor, and had its optical wheel bolted hard to the camshaft sprocket, rather than spinning on its own axle. This would have eliminated the cap and rotor, simplified plug wire routing, and eliminated the Opti shaft bearings as a point of failure (which commonly occurs soon after an Opti takes a coolant bath).
The Delteq and LTCC systems solve all of these problems except for the bearing issue.
Live well,
SJW
