Hard starts
Old Aug 17, 2011 | 09:36 PM
midnightrdr's Avatar
midnightrdr
Cruising
Default Hard starts
At wits end. 89 c4 would not start after short drive. After 1 hour of sitting started but ran very rough. After overnight sit, cranked ran fantastic.
Old Aug 17, 2011 | 11:19 PM
87 vette 81 big girl's Avatar
Possible the original GM Multec Fuel injector(s) are failing.
Common problem with these C4's & todays E10 gasoline.
Best solution if the injectors are failing is to replace all 8 at once.
BR
Old Aug 17, 2011 | 11:26 PM
jfb's Avatar
jfb
Similar thing happened a long time ago with my 87. It was a failing ECM.
Old Aug 18, 2011 | 01:42 AM
Ricky 91 vette's Avatar
Ricky 91 vette
Hi
I had exact same problem with my 91, turned out to be FPR diaphragm only, was leaking a little bit and I replaced it with auto zone part#
800-122 and problem was fixed!!
Old Aug 18, 2011 | 08:09 AM
Joe C's Avatar
Joe C
might be a fuel problem, but we're just second guessing here. connect a pressure gauge to the fuel rail, run a test, and start with the basics.
Old Aug 19, 2011 | 03:37 AM
Ricky 91 vette
I would say do some thing easier than that first, simply pull the vacum hose from the FPR , have some one turn the key on u will hear the fuel pump running for 2 sec, have him turn it off and on again after like 10 sec sonu can hear it again while u r watching the little pipe on the FPR, if u see fuel coming out of it, it's bad then and needs to be replaced , If not then put the hose back and get a gauge to check ur fuel pressure, and see how long it holds after turning off the car, but I'm 99% sure u will see fuel though!!! I hope this help
Ricky
Old Aug 19, 2011 | 09:48 PM
corvettej's Avatar
corvettej
St. Jude Donor '13 thru '24
My 89 started doing the same thing this month would crank but not started, check the fuel pump first then check the injectors with a multimeter because I never change the injectors from when I purchased it new and two injectors were bad, one was at .001 ohms and the other one was at .014 ohms(which was marginal) the rest was at .016 ohms which was good, but I replace all of them with a new set of bosch injectors and she's been running fine ever since with great response an better fuel mileage. Good luck
To Hard starts
