Here is what I have so far
Old Aug 18, 2011 | 08:59 PM
Strick's Avatar
Strick
Default Here is what I have so far
[IMG][/IMG]
On my way to converting to a LT4 from a 92 LT1. I still need the Hot cam kit and 95 opti and all the gaskets. I'll be taking pictures along the way. If anyone has done this upgrade and has a few pictures or advice please jump in.
Old Aug 18, 2011 | 09:20 PM
mistaben's Avatar
mistaben
/strongstartisstrong
i would recommend figuring out your hp range and then needed injector size while your here... something I didn't do when I planned mine and am now asking all over about also tuning.
Old Aug 18, 2011 | 09:59 PM
Dr.Huxtable's Avatar
Dr.Huxtable
wow those headers are gorgeous what brand are they?
Old Aug 18, 2011 | 10:27 PM
Strick's Avatar
Strick
EM's Got a great deal on a group purchase. I still need the cats and extentions to my catback.
BTW, I followed your thread on the clutch deal, WOW! But I learned a lot from it.
Old Aug 18, 2011 | 10:28 PM
LT1*C4's Avatar
LT1*C4
Your '92 had a "one year only" opti harness which has a square-end connection on one end and a short connection on the opti-side. If you're updating to a later style vented design, you'll have to upgrade the harness as well.
You can do this by either buying a later-model harness, cutting off the one end and splicing in your '92 specific square end, or, even easier, buy a harness that's already been spliced for you for a quick, simple, plug and play swap.
Should only run you up another $45 or so which, judging by the amount of money you've spent so far, shouldn't be that big of a deal.
Here's a place that sells the harness I'm referring to.
Hope this helps. Good luck with the upgrades.
http://www.nookandtranny.com/mm5/mer...egory_Code=WIR
Old Aug 18, 2011 | 10:36 PM
Strick's Avatar
Strick
I can only average what other guys posted for hp ranges and that would be around 400 plus at the crank. That's good enough for now. I also learned that injectors on the LT4 are 28lbs and they should be fine, but I haven't bought those yet. Maybe 30lbs would be better? For tuning, I'll be going with PCM here on the forum.
Old Aug 18, 2011 | 10:41 PM
Strick's Avatar
Strick
Wow, thanks for the info. I looked at the Edlebrock LT1 to LT4 swap kit and I'm no where near in cost to what their's is. I'm just buying a part here and a part there. This fall/winter will be fun time in my garage
Old Aug 18, 2011 | 11:20 PM
mistaben's Avatar
mistaben
well if your asking me on the fuel injectors... (i'm not a tuner btw, just trying to finish my build off, lol)... I can give you this:
http://www.ajdesigner.com/phpengine/...efficiency.php
http://users.erols.com/srweiss/calcpchg.htm
http://www.z31.com/software/injector.pl
http://forums.corvetteforum.com/c4-t...questions.html
http://www.bgsoflex.com/pwcomp.html
Or, I can tell you to call John Banner, at FICinjectors, and have him select the appropriate size Bosch 3's to fit your engine. it's what I finally did today.
Old Aug 19, 2011 | 12:40 PM
neverendingprojects's Avatar
neverendingprojects
I second this part, Bought my 95+ opti conversion harness from these guys on ebay when I cammed and rebuilt my engine... It was a nice plug and play deal with no wire spliceing!
You should create a thead when you start swapping for us to enjoy... Also, Im interested in hearing about PCM mentioned and the tuning on this build...
Good Luck!
Old Aug 19, 2011 | 01:11 PM
Strick's Avatar
Strick
I do plan on taking photos and writing a journal about the build. It'll be our own reality show right here on CF. I'll use the FSM for most of my information because it sets up a good checklist of things to be done and in order. But there is always something that it doesn't explain very well or assumes you know how to do. What I need is a better photo program than what I have on my computer. Mine is too complex just to load photos.
Old Aug 19, 2011 | 01:19 PM
STEVEN13's Avatar
STEVEN13
Good luck Strick!
Post dyno numbers when completed.
Steve
Old Aug 19, 2011 | 01:23 PM
Strick's Avatar
Strick
Good Luck!
I just ordered the harness. Thanks for the tip and link. My third online order. This is too easy.....could be dangerous.
Old Aug 19, 2011 | 01:24 PM
Strick's Avatar
Strick
Originally Posted by STEVEN13
Good luck Strick!
Steve
I hope to do just that. We 92 owners have to stick together.
Old Aug 19, 2011 | 01:46 PM
cv67's Avatar
cv67
St. Jude Donor '05
thought about doing any porting before it goes together?
Old Aug 19, 2011 | 03:13 PM
pologreen1's Avatar
pologreen1
Good luck Strick!
Steve
LT4= 400 IIRC
Old Aug 19, 2011 | 03:14 PM
pologreen1's Avatar
pologreen1
Hopefully so. Then it will make a serious difference in performance over the LT1 at least.
Old Aug 19, 2011 | 05:42 PM
Caboboy's Avatar
Caboboy
If you do, send it to Ron..........he's da MAN!
It looks great Strick, what an exciting time!
To Here is what I have so far
Old Aug 19, 2011 | 06:16 PM
Strick's Avatar
Strick
I'm not doing any major porting, just port matching and polishing. I'd sure like to learn how to polish the ports.
Now that I have most of the harder parts to get in hand, I'm really getting excited to start this upgrade. Once I have ALL the parts in hand and my garage is spotless, I'll pull the trigger and start the fun.
Old Aug 19, 2011 | 06:42 PM
Mohammed_z's Avatar
Mohammed_z
sexy pic, i'm jealous I want headers , how much did you pay for the headers ?
what's in the black box ?
Old Aug 19, 2011 | 09:59 PM
Strick's Avatar
Strick
The black box is the Kent-Moore tool for removing and installing the LT1/4 crank hub. I just bought it as I didn't want to struggle with that again. The headers were around $500, but that was a few years ago. Like I said, I've been collecting these parts for a long time.
