Power Window on 1984 Needs Replace Which way to go ???
Old Apr 29, 2002 | 03:06 PM
1986vert's Avatar
1986vert
Default Power Window on 1984 Needs Replace Which way to go ???
I have both of my power window motors getting really slow and sometimes won't raise the window without a little help. Should I update both to the newer
1986 and above or just replace the motors ?? It is about 100.00 difference per door and what ever it takes to install it labor wise, and would it take that much longer to install ??? Thanks
Old Apr 29, 2002 | 03:59 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: Power Window on 1984 Needs Replace Which way to go ??? (lee.anderson)
lee, i thought you sold her??? i just replaced both of mine (before i paint her). i got them at advance auto new for $45.00 each & installed them myself. it really isnt that hard of a job just take your time & do 1 at a time. good luck. :cheers:
Old Apr 29, 2002 | 05:47 PM
1986vert's Avatar
1986vert
Default Re: Power Window on 1984 Needs Replace Which way to go ??? (yoslambo1@cs.com)
I have a couple and you just replaced the motors ?? Do you have to pull the whole assembly to replace just the motor ? Thanks and I still have another
in storage, I have this thing for 1984 and also for 1989 but haven't found the right 89 yet.
Old Apr 29, 2002 | 06:42 PM
ralph's Avatar
ralph
hands down...get the new style window regulators!!!! You wont be sorry.
Old Apr 29, 2002 | 07:31 PM
JOHNL's Avatar
JOHNL
Default Re: Power Window on 1984 Needs Replace Which way to go ??? (ralph)
If Your planning on keeping Her for awhile then Upgrade for sure.
Old Apr 29, 2002 | 09:35 PM
JonM's Avatar
JonM
Check it out .... http://www.corvettemagazine.com/2000.../windowpg1.asp
Old Apr 29, 2002 | 10:06 PM
1986vert's Avatar
1986vert
Default Re: Power Window on 1984 Needs Replace Which way to go ??? (JonM)
John,
The link takes me to an error .....
To Power Window on 1984 Needs Replace Which way to go ???
