Help on wiring a Flameball shifter???
Old Apr 29, 2002 | 04:41 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
Default Help on wiring a Flameball shifter???
Hi guys, I've got the **** on, but have no clue on how to wire this thing so that it wil light up. Can anybody help me, please???
Thanks in advance. :)
[Modified by 96LT4, 3:41 PM 4/29/2002]
Old Apr 29, 2002 | 05:25 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Help on wiring a Flameball shifter??? (96LT4)
Well one of 2 ways..
if you want it connected to the Parking Lights. on the back of the radio control head one of the connectors has 2 grey wires.. one (pin 4) is the Light dimming line. connect one wire from the bulb to that and the other to ground.
If you want it lit when the car is on.. then when you remove the console piece with the shifter boot there should be 3 wires that are pig tails.. find the switch wire and the ground and wire to that. I have me flame ball on my car right but took the bulb out for now. With the reverse lock out rig I cannot hide the wire very well.
Old Apr 29, 2002 | 06:52 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
Default Re: Help on wiring a Flameball shifter??? (-=Jeff=-)
Jeff, thanks for the reply. How do you get the shifter boot off?? The rest soundss fairly simple. :)
Old Apr 29, 2002 | 07:50 PM
-=Jeff=-'s Avatar
-=Jeff=-
well you can do it with the console plate on the car..
I woud feed the wires down the front through the seam. but to take the boot off the ring on the shifter should pull up and off.. do this after the console plate is off. You will also have to pull the console lid off as well
Old Apr 30, 2002 | 03:12 AM
1CanuckVette's Avatar
1CanuckVette
Any chance of a pic of this thingy called a flame ball, sounds interesting. :cheers:
Old Apr 30, 2002 | 04:05 AM
BlackRocket's Avatar
BlackRocket
There are lots of these shifters at http://www.flameball.com.
Old Apr 30, 2002 | 10:10 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Help on wiring a Flameball shifter??? (1CanuckVette)
Here is mine
To Help on wiring a Flameball shifter???
