8 grand tach
Old Aug 21, 2011 | 08:23 PM
DoctorG17's Avatar
DoctorG17
Default 8 grand tach
I have a 6 grand tach on my 1990 corvette, I would like to change it to 8 grand tach. Were can I get a 8 grand overlay.
Old Aug 21, 2011 | 09:57 PM
1991Z07's Avatar
1991Z07
A ZR1 cluster will work as well...
Can be found in some salvage yards.
Old Aug 21, 2011 | 10:32 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Can a 90 Vette make it to 6,000 RPMS?
Old Aug 21, 2011 | 10:36 PM
jfb's Avatar
jfb
Just pay youself $2000 and you will have an eight grand tach.
Old Aug 22, 2011 | 09:19 AM
DoctorG17's Avatar
DoctorG17
Im putting a 383 in the car, I have an extra 6 grand tach, would like to change it , thanks.
Old Aug 22, 2011 | 09:43 AM
jfb's Avatar
jfb
There is a calibration pot in the circuit board of your current 6000 rpm tachometer, but I doubt it has the adjustment range to increase the full scale to 8000 rpm. You can install a fixed resistor in series with the pot depending on the calibration schematic to increase the full scale rpm, but then you will also have to change the scale on the meter face to read to 8000. If the tach is digital readout you won't have a meter face to change. Usually it is difficult to obtain a schematic of a tach which is what you need to decide how to increase its full scale rpm.
Old Aug 22, 2011 | 01:00 PM
LTxDave's Avatar
LTxDave
Lingenfelter used to convert your tach, but I don't know if they still do or not. I am using one out of an LT4 in my 95, but as mentioned above, you could try to find one from a ZR1.
To 8 grand tach
