84 help:high idle
Old Aug 22, 2011 | 11:14 PM
joecv's Avatar
joecv
3rd Gear
Default 84 help:high idle
HELP PLEASE. High idle when car starts.(11-1200 RPM) Does not throttle down. 0-25 hesitates then runs real smooth. Any suggestions on what to check?
Appreciate any one's experience with this
Thanks J
Old Aug 22, 2011 | 11:26 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You have a vacuum leak. Find and fix the vacuum leak and the high idle will go away, the hesitation may go away (Check your fuel pressure for that if it persists) and the engine will run better in general. Fix the vacuum leak(s)!
Old Aug 23, 2011 | 12:55 AM
ex-x-fire's Avatar
ex-x-fire
The 84s have an odd style coolant temp sensor that is troublesome, wiggle it to see if the idle changes.Its under the air pump, screws into the intake. You can retrofit a newer style sensor/connector if you feel its a problem. I think the 85s started using them.
Old Aug 24, 2011 | 09:23 AM
84cfi's Avatar
84cfi
This is definitely the problem I replaced my temp sensor and now it idles perfect. It is not a vacuum leak
Old Aug 25, 2011 | 10:31 PM
joecv's Avatar
joecv
3rd Gear
Thank you for your advice. The sensor at the front of the block driver side...I pulled the connector off while running and no change in idle....if that's the one does that indicate it is bad?
Thanks, Joe
Old Aug 25, 2011 | 11:36 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Wrong coolant sensor. You just "checked" your coolant gauge sensor. The CTS for the ECM is located on the front of the intake, slightly to the passengers side.
FYI, 11-1200 RPM is normal for a cold start up on a CFI car.
To 84 help:high idle
