clutch fluid question
Old Aug 24, 2011 | 11:46 AM
petrov83's Avatar
petrov83
Default clutch fluid question
i have a 96 6spd and it is losing some clutch fluid. I have to refill once per month. I have a question about what that black rubber upside down magician hat looking thing is inside the clutch refill container. I mean it takes like almost the entire volume!!! I can fit like a bottle cap of clutch fluid in there. Anyway I can put more fluid? Make a small hole in it and cap it off with fluid on the inside as well?? I am barely losing fluid but with just space for a couple of ounces i have to eventually refill every month. Also any stop leak additive out there? If someone can please tell me what that rubber does ill be very greatful. And if I can just go w/o it.
Old Aug 24, 2011 | 02:04 PM
mtwoolford's Avatar
mtwoolford
compress the magicians hat flat...just like a magicians hat, fill reservoir, lay the now flattenned hat on top. It forms a barrier between the atmosphere and the fluid; just make sure that when the "magician's hat" opens (as the fluid level drops) it opens downward towards the fluid.
Old Aug 24, 2011 | 02:30 PM
don hall's Avatar
don hall
Not true ....... clutch reservoir 'hat' does not compress. You are mistaking this 'hat' for the brake fluid 'hat', which compresses.
Check the slave cylinder for leaks..... common problem.
http://tech.corvettecentral.com/2007...1996-corvette/
Old Aug 24, 2011 | 02:54 PM
petrov83's Avatar
petrov83
thats true the rubber gasket(hat looking thing) does not compress and its really stupid how it takes like 90% of the volume. Anyway around it?
Old Aug 24, 2011 | 03:04 PM
c92vette's Avatar
c92vette
I can fold mine up and have no problem. It takes a little manuvering to do it but it can be done. You need to place it back in the resevoir so it unfolds toward the used fluid. I've been doing this for the last 14 years about once every 6 months. Eventually I will get around to replacing both the slave and master but for now as small a nusience as it is I won't bother. I never see any wet fluid around anywhere but I suspect it's the slave.
Old Aug 24, 2011 | 03:10 PM
petrov83's Avatar
petrov83
well ill give it a shot unless someone comes up with a better solution. The amount that leaks out is so small that it probably evaporates before it even has a chance to leave a trace.
Old Aug 27, 2011 | 02:31 AM
matanki's Avatar
matanki
6th Gear
Default Stupid question
Hi Everyone!
I'm very new to this site and Corvette. I just purchased a 1984 Manual trans Corvette. I opened the Hood to check all of the fluid levels, and found all of them filled, except one. It isn't labeled, but is on the driver side firewall. Could anyone tell me what it is for, and what kind of fluid that I need to fill it with.
Thank you!
Old Aug 28, 2011 | 05:17 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Originally Posted by matanki
Hi Everyone!
Thank you!
Under the computer = Clutch master.
Quality dot3 brake fluid works.
To clutch fluid question
