Opti-Spark, What problems have been encountered??
Old Apr 29, 2002 | 11:33 PM
Denney's Avatar
Denney
Default Opti-Spark, What problems have been encountered??
I routinely hear moans and groans about the Opti-Spark and although I haven't had any problems with mine (107k+ miles) I was wondering what others have experienced (problem wise) with theirs? Maybe, if this has been discussed previously, someone can point me to an old thread? Thanks.
Old Apr 30, 2002 | 12:11 AM
92LT1Roadster's Avatar
92LT1Roadster
Default Re: Opti-Spark, What problems have been encountered?? (Denney)
Well first of all it is apperent that you have not made the mistake of washing your engine without covering the opti :D. The problems are slight at first. Marginal hesitation on full throttle. Then it becomes worse to the point of backfiring and then "total system shutdown" It kindda attacks your car like a virus does the body :eek: . This can be solved a number of ways
1. If you have a 92-94 car : cost of opti=- between 365 - 545 (These are notorious for water moisture damage because the cap does not vent)
you can add the vent kit for 30 buck to prolong the life of your
labor nomally around $400 - 500... most replace the water pump while they are there
2. or you can upgrade to the 95? and 96 model. 150 - 200 dollar model. you will need to change your timing change cover and I think a spindle on the cam shaft.( I am not too sure)
I replaced mine at 70k. when it occured I thought I had thrown a rod or something :D
[Modified by 92LT1Roadster, 10:13 PM 4/29/2002]
Old Apr 30, 2002 | 12:45 AM
Dan Parker '96's Avatar
Dan Parker '96
Personally, I believe the Opti to be as or more reliable than any of the "conventional" distributor systems. You'll just hear more of a stink about in these forums (god bless the internet).
But this "old tech" has proven itself in my father's '85 300zx turbo (160K)which happens to use the same system. GM is a little slow on the uptake but will adapt to proven tech when the bean counters let 'em.
Old Apr 30, 2002 | 01:11 AM
95RedRocket's Avatar
95RedRocket
4th Gear
Speaking of this subject, I'm currently replacing the water pump in my 95 LT1 and was thinking of cleaning the engine while I'm at it. Any suggestions on what to use to clean it and how to properly cover the opti to prevent problems?
I made the mistake of hosing down the engine on my 94 LT1. It worked fine the day I cleaned it but on the second day, it did act like it had a virus and completely shutdown. She was fine though on the third day.
[Modified by 95RedRocket, 5:17 AM 4/30/2002]
Old Apr 30, 2002 | 05:37 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Re: Opti-Spark, What problems have been encountered?? (Dan Parker '96)
Believe in Santa Clause too ?
Old Apr 30, 2002 | 09:19 AM
RichS's Avatar
RichS
Default Re: Opti-Spark, What problems have been encountered?? (AquaMetallic94LT1)
I had a 95 with 32,000. Now the GS with 32,000 as well. When I had both motors apart I also took apart the Opti in them. Both were spotless inside and I have not had any opti problems.
Old Apr 30, 2002 | 10:35 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Don't wash down the engine. If you need to clean it, do it by hand. When you wash the engine, or get water on the Opti-spark (92-94) you will experience hesitation and perhaps backfiring.
Old Apr 30, 2002 | 10:59 AM
93LT1's Avatar
93LT1
Yep! I was one of the early adopters of the "clean your engine syndrome"
I was able to hop to the GM dealer and get it fixed. Now that I've discovered this EXCELLENT forum, I'm a much wiser and educated
vette enthusiast. Other than that mishap, the Opti has been very reliable
( crossing my fingers) with over 60,000 miles on it. I am planning on taking
a proactive role and replacing the unit. I just haven’t decided
on which route to take... early or later style. :)
Hank
Old Apr 30, 2002 | 08:12 PM
John Row's Avatar
John Row
The concept of the opti is great, it's the execution that leaves a lot to be desired.
1. Location - under the water pump. A really good place for electronic and electrical equipment. To say nothing about how much fun new plug wires are.
2. Seals, they toast up nicely over time. Toasted seals don't.
3. Open vents, three of them. See #1.
4. Electronics plug with a split base. See #2.
Having said that, the 95-96 optis fixed all these problems. I don't recall anyone with the new one complaining about not being able to clean the engine or replace the opti. New plug wires are still an issue.
Old Apr 30, 2002 | 09:56 PM
emoshn's Avatar
emoshn
I agree with Dan. Mine had 102K on it with no problems. I replaced it this winter along with the water pump. New wire & plugs. The car DOES run better now, but I think it was the plugs and wires that did that. The old opti looked great inside, and the original waterpump wasn't leaking (and they were both original equipment). So I kep em! The new one's will probably fail.
Maybe I've got a "Wednesday car", but any distributor that works flawlessly for 102K+miles deserves a round of applause.
Old Apr 30, 2002 | 10:40 PM
STL94LT1's Avatar
STL94LT1
Mine failed at 12,000 miles.
Old May 1, 2002 | 11:51 AM
Rick93Z07's Avatar
Rick93Z07
Default Re: Opti-Spark, What problems have been encountered?? (STL94LT1)
You will not experience any premature failures with an early Optispark if you spend $15 to $20 to properly seal and purge vent it. You do not have to procrastinate until it fails either, so you can experience the inconvenience of a AAA tow job. Most functional Optisparks can be modified to greatly extend their lifespan for reuse without replacement. You do not need to tear the whole motor apart and spend many hundreds in parts to convert to later style Optispark. That option is more costly, more complex and does not produce better results. Comparing the costs of the two vintages of Optispark distributors is misleading and a total fallacy. The later style does not bolt-on without other conversion componentry...including an expensive cam that's very difficult to install.
Old May 1, 2002 | 01:53 PM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
I washed my engine once and my car would start, but then die unless I kept hitting the gas. 2 days later everything was fine, not a problem since
To Opti-Spark, What problems have been encountered??
