Two cosmetic dash questions. 1985
Old Aug 29, 2011 | 03:07 PM
patvette's Avatar
patvette
Default Two cosmetic dash questions. 1985
Still rebuilding this beast.
1. What holds the dash pad down on the passenger's side above the crash pad in the corner? I don't see any screw holes and my dash doesn't have a clip there. The problem is that that far corner is raised and bounces when I drive.
2. Is there a piece of trim above and all across the top of the crash pad? I can see under the dash through a 1/2 inch or so space showing the crash pad's two brackets.
Hey, maybe fixing #1 woulod improve #2 !
Old Aug 29, 2011 | 04:14 PM
LD85's Avatar
LD85
Remove the side fuse panel cover and there is a screw there on the corner
Old Aug 29, 2011 | 04:25 PM
patvette's Avatar
patvette
Thanks. On my car, there is no screw. When you face the fuse box from the passenger door, there is a hole for a screw in the upper left side, but even if I had a screw, there is no way it would reach the couple of inches above where the dash pad is. Am I missing a part maybe? Is there supposed to be a bracket that hangs down from the dash pad?
Old Aug 29, 2011 | 05:32 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
The crash bump pad is primarily held by non-visible brackets. IIRC, they are pop-rivited to their mounting points. It takes gymnastics to get it off. I cut at least one bracket since I was replacing it with a flat panel.
There is no strip across the top. Left and right are the mounts. The right panel (that has the fuse cover built-in) does cover the right end of the bump pad, but has nothing (that I know of) to do with the top dash hold-down.
There is a 1"x1"strip on either side that extends from the inner windshield trim, curves down the window brace and stops at mid-door jam. This piece aids in putting downward pressure on the very corner of the dash pad.
When I redid my car, I ended up making two felt strips for the ends of the dash pad. I glued them to the dash pad where it meets with the windshield pillar. This helped suppress squeaks.
Mostly, I believe the dash pad is held in place by: clips at the front corners, screws in the defroster vent, screws above the dash, and screws above the radio bezel. Rigidity of the entire piece does the rest. But, I think it needed something at the rear corners to help with stability as you suggest.
Old Aug 29, 2011 | 06:49 PM
pmihaltian's Avatar
pmihaltian
Slingshot
See attached write-up
File Type: pdf
To Two cosmetic dash questions. 1985
