Heads opinion
Old Aug 30, 2011 | 03:41 PM
weaselbeak's Avatar
weaselbeak
Default Heads opinion
Hello all I'm working over my l98 and was wondering what your thoughts were on these heads.
http://cgi.ebay.com/ebaymotors/sbc-c...item2566fd5c95
I would order the 190 with the angle plug with the 64 chambers. I've not yet picked out a cam yet and I'm still debating on whether I can swing AFR's from Jim. I called and talked to the guys at firstfuelinjection and will be getting their intake setup.
If these heads are ok they represent enough savings over the AFR's that I could spend more on the tune or maybe go with some obx headers. I'm not looking to start an AFR vs the world debate again I read enough of those with the search function.
So these heads, try for the AFR's or go for a brodix or edelbrock? With my limited knowledge should i just be looking at top end packages which have the head and cam together?
Thoughts? Thank you.-just a street car, no racing.
Old Aug 30, 2011 | 05:59 PM
Rohn's Avatar
Rohn
Search ProComp see what others have said. Brodix/Dart are much more cost but some say worth it.
Old Aug 30, 2011 | 06:02 PM
tpi 421 vette's Avatar
tpi 421 vette
Hey Jeramy, if you go with AFR's, you would want the AFR 195 heads #1040 unless you are using a Vortech style intake. The AFR 190 is a Vortech specific cylinder head.
Old Aug 30, 2011 | 10:23 PM
cv67's Avatar
cv67
St. Jude Donor '05
I can take a set of 2000.00 castings and make them junk in 5 minutes or less.
Dont skimp when it comes to heads, if youre going to use the FIRST def. get the AFRs
Maybe those are Ok but those ads for the cheapie heads all look the same, their buddy works at a track they even got stickers on their car, their dog watches Nascar with them, etc. Not one flow # on there either.
not really confidence inspiring
Old Aug 30, 2011 | 10:24 PM
84wannabezo6's Avatar
84wannabezo6
If you change to 64cc chambers you will lose compression are you changing pistons? or deck height or head gasket thickness
Old Aug 31, 2011 | 07:05 AM
weaselbeak's Avatar
weaselbeak
Thanks for steering me back straight Jim. I'm planning on running the stock pistons so I'm thinking a thinner head gasket to maybe bring some of the cr back. I will avoid these types of heads in the future then.
Opinions on the edelbrock top end packages? If I have to spend 1k on heads then I'll just order the afr's from Jim. I was just thinking that maybe an $800-$900 set plus headers would do me as well as a $1300 set of afr's. I will also check out the procomps and brodix as suggested.
Old Aug 31, 2011 | 08:03 AM
Muffin's Avatar
Muffin
Do I read the ad correctly, $750. for one head or is that for a pair? If that is for a pair I do not see how he can do it. Springs and valves alone would run almost half that.
Old Aug 31, 2011 | 08:26 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Per pair....a pair of bare heads are $555.
Old Aug 31, 2011 | 08:29 AM
BADDUCK's Avatar
BADDUCK
You can get them milled to correct chamber size.
Old Aug 31, 2011 | 08:31 AM
weaselbeak's Avatar
weaselbeak
Badduck would you use a thinner head gasket and mill the heads-or just mill the heads and use a regular head gasket?
Old Aug 31, 2011 | 08:40 AM
87 vette 81 big girl's Avatar
Bullchit add on ebay.
Read through add.
Does not prove chit to me.
AFR Or BRODEX.
Others suck AZZ.
Old Aug 31, 2011 | 09:48 AM
BADDUCK's Avatar
BADDUCK
Depends on your goals and overall setup. Milling can cost $'s. You might get a quote. BTW, if you don't go with AFR's you will get shouted down on this forum.
Old Aug 31, 2011 | 10:30 AM
cv67's Avatar
cv67
St. Jude Donor '05
You cant use the stock manifolds with the AFRs,in fact even with other performance heads you should run headers, youll only be choking the motor. You will get what you pay for with heads. Save a few hundred make noticeably less power, nothing will make up for it. made that mistake yrs ago and totally regretted it. "The almost the good as head for $200 less" I picked up sucked, didnt feel much different than stock.
Old Aug 31, 2011 | 10:35 AM
tpi 421 vette
You can flat mill the AFR's to 60cc's. Beyond that will require an angle mill. A flat mill and a thinner gasket would bring your compression right back to where it is now.
Old Aug 31, 2011 | 10:42 AM
weaselbeak's Avatar
weaselbeak
When you say I cannot use the factory headers with the afr's is that because they won't fit or just because it would be a silly thing to do. I ask because I purchased some hedman longtubes for the l98 heads which I never installed. If I got the afr's I was going to use them instead of buying the nicer obx's
Old Aug 31, 2011 | 11:05 AM
cv67's Avatar
cv67
St. Jude Donor '05
They wont cover the exhaust port and they are extremely restrictive.
Old Aug 31, 2011 | 11:40 AM
weaselbeak's Avatar
weaselbeak
Ok I broke down and gave TPI_421 a call. I like dealing with him because he's a good guy who knows his @#!. Ordered AFR 195's that I'm having AFR flat mill down to 60cc's for me. AFR's doing the milling and will make sure they don't cause me any alignment issues with their work.
It was a bit of money for me to cough up at once but in the end I think it will be worth it. I didn't want to have to worry about bad springs or things that were prematurely wearing because they used @#! components. Jim got me the heads flat milled and shipped to my door for right around what just the heads would have normally retailed for.
To Heads opinion
