egr solenoid
Old Apr 30, 2002 | 03:35 PM
Frank92's Avatar
Frank92
Default egr solenoid
i ordered a wrong part. it an egr solenoid. i´m not sure if i should send it back or install it. if this part could be bad (it.s not bad yet) after 80 k miles i´ll change it.
frank92
Old Apr 30, 2002 | 03:58 PM
The Gooch's Avatar
The Gooch
St. Jude Donor '06-'07-'08-'09-'10
Default Re: egr solenoid (Frank92)
Are you asking a question or just making a statement :confused:
Old Apr 30, 2002 | 04:40 PM
emoshn's Avatar
emoshn
Default Re: egr solenoid (GWH)
Change it...it's cheap insurance...and takes all of about 10 minutes to change.
Old Apr 30, 2002 | 05:34 PM
JonM's Avatar
JonM
I doubt if you can send it back if the package has been opened. Elec. parts are usually non returnable
Old May 5, 2002 | 11:34 AM
Frank92's Avatar
Frank92
Default Re: egr solenoid (JonM)
i`ll change it. it`s really cheap insurance. i think it`s located under the fuel rail cover, passenger side?
frank
Old May 5, 2002 | 11:50 AM
ittlfly's Avatar
ittlfly
It's located on the drivers side under the cover near the back of the intake. Just take your time when removing the vaccum tubes. Also check the vac. "tee" for cracks underneath it...famous for vac. leaks ...
[Modified by ittlfly, 7:50 AM 5/5/2002]
Old May 8, 2002 | 04:29 PM
Frank92's Avatar
Frank92
Default Re: egr solenoid (ittlfly)
i ordered the "t" bt i got the solenoid. I´ll change it. thanks
frank
To egr solenoid
