fuel rail fitting question
Old Sep 1, 2011 | 10:19 PM
llong66's Avatar
llong66
Default fuel rail fitting question
Hi, I have a 92 that I am getting ready to put a Zex wet kit on, I also want to be able to monitor my fuel pressure while on the bottle, does anyone make a T fitting for the fuel rail so I can put a sending unit for a gauge and the tap for the fuel for the nitrous? I know there is not alot of room in there so I am not sure what my options might be
Old Sep 1, 2011 | 10:57 PM
526hp89's Avatar
526hp89
I used a 1/8"npt street T at the fuel solenoid for my wet kit. The solenoid needs to be grounded also so it works for a electric sender plus all your wires only need to be run to one spot. By the way a street T will have a male at one end to go into your solenoid and and two female ports one in the middle and one at the opposite end from the male fitting
Old Sep 1, 2011 | 11:17 PM
llong66's Avatar
llong66
thanks, never thought about taking the pressure from the the solonoid!
Old Sep 16, 2011 | 05:00 PM
Mo_Bandy's Avatar
Mo_Bandy
When I was supercharged, I connected the pressure sensor to the schrader valve... ( I removed the "valve stem" ).
The solenoid is also a great idea!
MO
To fuel rail fitting question
