why wont tunerpro read this memcal? (pics inside..)
Old Sep 3, 2011 | 12:15 AM
mistaben's Avatar
mistaben
Default why wont tunerpro read this memcal? (pics inside..)
Chip Reading and Programming
Connect the AutoProm to the USB cable. The USB will supply the power.
Make sure the 28 pin ribbon cable used for emulation is UNPLUGGED from the unit. Unpredictable behavior can result from the APU1 being directly connected to a ECM using the emulation cable while burning chips.
Place the target or source chip in the ZIF socket.
Orientation is critical, and the chip should be placed with its notch or arrow facing toward the ZIF handle and toward the back panel of the AutoProm. The chip should be at the ‘bottom’ of the socket, such that any unused socket pin slots are closest to the handle or backplane.
Use a supporting software program, such as TunerPro or FlashBurn to pick read/write operation, file location and name, starting and ending addresses, any hex offsets, bank selection, or other characteristic of the read/write operation. Carry out desired program/read/verify steps as desired, and remove chip from socket.
- ok... followed those steps
... now why wont tunerpro read the memcal?
Old Sep 3, 2011 | 01:48 AM
mistaben's Avatar
mistaben
also I can't seem to get tunerprort to connect through my ALDL.
it keeps giving me:
can not connect to port
Old Sep 3, 2011 | 02:19 AM
mistaben's Avatar
mistaben
HIIIIZZZAAAHHHH I FINALLY FIGURED OUT HOW TO DO IT!!!!
To why wont tunerpro read this memcal? (pics inside..)
