PKE Unit Location
Old Apr 30, 2002 | 06:56 PM
mn_vette's Avatar
mn_vette
Default PKE Unit Location
I took my car to the dealer and they told me that my PKE unit had died. The light on my DIC is lit up and it's a pain having to use my key, yes I got spoiled off of it. I need to replace the unit, but I have no clue where it is or how to get to it. Can anybody help?
Old Apr 30, 2002 | 07:38 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: PKE Unit Location (mn_vette)
If I remember it's in the back underneath the carpet along the wall. Been a while as mine doesn't have it. I have to go the hard way and use a key :)
Old Apr 30, 2002 | 09:26 PM
Red Dwarf's Avatar
Red Dwarf
The PKE module shud be located behind the DIC & under the tone generator. I think you may have to pull the upper trim panel to access. Don't know if you can get at it thru the DIC (removed). This is for a 95, I assume yours is the same.
Old May 1, 2002 | 10:39 AM
GS-598's Avatar
GS-598
The PKE module is directly behind the DIC on the inside of the dash panel. The shop manual says to remove the dash pad for access. Although not really hard, it is a fair amount of work.
However, Last year at the Gathering, we had a trip to Gordon Kilebrew's place and I got some time to talk to him about this same issue. He showed me how he removed the DIC, then using a dremel tool or small saw, carefully cut out the plastic behind the DIC. It is not a structural piece and will not cause any problems. Through this hole you car reach in and remove the PKE module. It is held in place with velcro. I hope this helps, good luck.
:cheers:
Dennis
GrandSport #598
Old May 1, 2002 | 10:46 AM
mn_vette's Avatar
mn_vette
Default Re: PKE Unit Location (GS-598)
Thanks guys,
Now I need the replacement unit, does anyone know where I can get one and how much it'll run me?
Old May 6, 2002 | 01:13 PM
mn_vette's Avatar
mn_vette
Default Re: PKE Unit Location (lou sylvestri)
I removed my DIC and saw two black boxes behind it. Cutting the plastic shouldn't be a problem, but which box is it. The small one on top or the bigger one on the bottom?
Old May 6, 2002 | 02:48 PM
Goody's Avatar
Goody
Its the small box on top, the other is the CCM. :seeya
To PKE Unit Location
