Crankshaft Harmonic Balancer Removal
Old Sep 3, 2011 | 09:40 PM
asjwalsh's Avatar
asjwalsh
Default Crankshaft Harmonic Balancer Removal
OK guys, loads of threads on this subject...but!
There are those who beat it off with wood/brass/whatever.
Those who used a crow-bar ??
Those who used a pulley puller.
Those who bought the GM tool (currently $400)
All these methods except the puller and tool seem a bit neanderthal, not that I have any problems with these, but I cannot for the life of me work out where/how to introduce the wood/brass to the inner part of the pulley. The car has been on jacks for 1 week now. All is ready for the pulley removal and I have read numerous threads on bashing the thing off. Any photos out there of where to place the bludgeoning tool?
Want to get it off this weekend, any guaranteed methods besides brute force?
Cheers,
Andrew
Old Sep 3, 2011 | 09:47 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
http://cgi.ebay.com/ebaymotors/LT1-L...item1c1e8be2b6
Old Sep 3, 2011 | 11:05 PM
asjwalsh's Avatar
asjwalsh
thanx, I looked at that too, but will it work? Any experience out there? If it is guaranteed I will drop the cash, but if not......
Old Sep 3, 2011 | 11:31 PM
383vett's Avatar
383vett
Pullers are inexpensive. Use the right tool or buy another balancer.
Old Sep 3, 2011 | 11:37 PM
asjwalsh's Avatar
asjwalsh
OK, what does that mean? I understand that the right tool will do the job, but the GM tool is $400. That is not inexpensive. Which cheap tool will do the job? It would appear that this question has never been answered on here.
Old Sep 3, 2011 | 11:46 PM
a454corvette's Avatar
a454corvette
The ebay link IS the GM tool.
I used a regular puller, but had a good assortment of bolts/barstock to accomplish the job...and the advantage of the engine being out of the car.
Old Sep 3, 2011 | 11:53 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
AutoZone has tools for the backyard DIY'er. If you've got one nearby, see if they can set you up with a puller.
Old Sep 3, 2011 | 11:54 PM
asjwalsh's Avatar
asjwalsh
I wish the engine was out of the Vette!
Old Sep 3, 2011 | 11:55 PM
asjwalsh's Avatar
asjwalsh
Thanks Greg, I will pop down there soon and see if they can help out.
Old Sep 4, 2011 | 01:09 AM
GREGGPENN's Avatar
GREGGPENN
Oh yeah...I've also seen it posted that people have used one of the puller setups from Harbor Freight. Do you have a HF store in your area?
Maybe if you search for the four words "Harbor, Freight, crankshaft, and puller", you'll find a thread with the part number.
If you don't, their stuff is returnable. The price is right too. Can't be that many options on their shelves.
Probably set you back a whole $10-$20 if that's where you pick one up.
Old Sep 4, 2011 | 02:08 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
To remove the balancer there are three 5/8" bolts. Once they are removed you can tap the balancer from underneath the engine with a long 2 x 1 piece of wood and a mallet. Tap to the left and to the right and it will fall off on the frame.
To remove the hub, you need a puller. Yes, it is tight down there but, it can be done. You get better with practice.
Old Sep 4, 2011 | 04:00 AM
Cliff Harris's Avatar
Cliff Harris
I have had a Proto Tools puller for many years, but it didn't work on my '86 because the center bolt was too long and hit the crossmember. I bought a Lisle 45500 (about $18), which worked just fine.
Old Sep 4, 2011 | 04:26 AM
Joe C's Avatar
Joe C
, HOWEVER, the balancer on my 85 was a real booger. had some slight corrosion on the mating surfaces. ended up stripping out some of the threads on the loaner tool. ended up going to summit racing (retail outlet) - dropped a hundred bucks or so. got a puller, an installer, and one of those nifty crankshaft turning sockets. not GM/kent-moore quality, but decent stuff. sure made my job a lot easier.
Old Sep 4, 2011 | 07:34 AM
mfi's Avatar
mfi
I knocked it off with a long breaker bar from underneath..just make sure you don't hit the out ring and don't bash the hell out of it...cause it is connected to that crankshaft ...which doesn't like to be moved around too much..you have to spin the motor around so you can hit it evenly around..once off you just clean up the shaft and hole with some emery and it will slide back on...soak the hell out of the area with penetrant before.
Old Sep 4, 2011 | 08:03 AM
Strick's Avatar
Strick
First your motor is an LT1? If so, the damper must be removed from the hub. Rust has normally formed causing removal of the damper from the hub to be difficult. After removing the 3 bolts that hold the damper onto the hub, slide your self under the Vette so you can see the back side of the damper. You'll see that you can use a dowel (maybe 1" in diameter) to touch the back side of the damper. After soaking the hub/ damper connection area with PB Blaster or othe penetrant, Gently tap the damper (inside the outer ring if possible) on alternating sides until it pops off. Now use the Kent moore tool to remove the hub from the crank shaft. If you can get a Kent Moore tool for under $200 you got a good deal. BTW, AutoZone won't have that style puller/installer tool. Yes, it would be easier if the engine were out of the Vette, but then other problems might show up. KISS might rule here. Just remember, you're "bonding with your Vette."
Old Sep 4, 2011 | 08:10 AM
toptechx6's Avatar
toptechx6
Seems to be a lot of confusion about removing the balancer, the method the OP refers to as neanderthal IS the correct method.
Kent Moore tool J39046 is only required to remove the HUB which is a press fit on the crankshaft. The separate balancer is held to the hub by three bolts and with age will rust in place requiring some force to remove, it is not a press fit and in fact the tool mentioned will NOT remove it.
Old Sep 4, 2011 | 11:34 AM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
This is the way i removed the balancer, when you go to put it back on put some anti-seize on there and next time it will come off easier.
To Crankshaft Harmonic Balancer Removal
Old Sep 4, 2011 | 01:50 PM
383vett's Avatar
383vett
LT1 and L98 balancers are different. The LT1 balancer needs the outer part knocked off the hub. The L98 needs the whole balancer assembly pulled off the crank snout. The correct method would depend on what motor the op has.
Old Sep 4, 2011 | 02:32 PM
asjwalsh's Avatar
asjwalsh
it's a 94, LT1.
Old Sep 4, 2011 | 02:38 PM
383vett's Avatar
383vett
it's a 94, LT1.
Then beat on it!
