Antenna Motor Keeps Running
Old Sep 3, 2011 | 11:16 PM
76yellow's Avatar
76yellow
Default Antenna Motor Keeps Running
When I went to start my 87 Vette today the battery was dead. When I put the charger on it the antenna motor started running but the antenna does not move anymore. I have the battery unhooked for now but is there an easy place to unhook the antenna so I can drive the car ?
Old Sep 3, 2011 | 11:57 PM
DA1984VETTE's Avatar
DA1984VETTE
I took the following suggestion from Midnight 85 and it worked.
Lift your rear hatch then take off the plastic trim piece that covers the latch. You will see two connectors on the driver's side. Un plug the gray one and it will cut the power to the antenna.
Old Sep 4, 2011 | 08:00 AM
76yellow's Avatar
76yellow
I forgot to mention, mine is a convertible but I'll look for a connector back there somewhere....Thanks alot
Old Sep 4, 2011 | 11:39 PM
C4boy's Avatar
C4boy
That's exactly how mine is now . 76Yellow, I don't know how the verts are wired, but the connector has 2 plugs going into it and it has to be in the area of the antenna (or at least I'd think).
To Antenna Motor Keeps Running
