Wideband O2 question
Old Sep 4, 2011 | 03:06 PM
llong66's Avatar
llong66
Default Wideband O2 question
I have a 92 and am wanting to put an A/F gauge in my car with my nitrous setup. MY questions is this, if I get a wideband O2 sensor, can I nook the cars computer to it like the current narrow band sensor or do I need to have a whole new bung put in just for the widband and the gauge?
Old Sep 4, 2011 | 05:04 PM
jsiddall's Avatar
jsiddall
I installed an Innovate WBO2 sensor and it has two programmable analog outputs. I have one driving a gauge and the second is programmed to emulate a narrowband sensor for the PCM. Works great.
Jeff
Old Sep 4, 2011 | 11:43 PM
llong66's Avatar
llong66
Can you be a little more specific about the gauge you went with? I see they have one thats discontinued, plus a cpl of other choices. The MTX-L looks like it might be a good choice, it is here:
http://www.innovatemotorsports.com/products/MTXL.php
it specifically mentions 2 outputs, so I think it will work. Thanks so much for the link and info!
Old Sep 5, 2011 | 03:16 AM
383tpimachine's Avatar
383tpimachine
Jeff
Thats pretty trick. I would like to know which unit you went with as well
Old Sep 5, 2011 | 10:40 AM
jsiddall's Avatar
jsiddall
I bought an O-Meter/LC-1 combo from Moates:
http://www.moates.net/ometer-and-lc1....html?cPath=48
I usually have a netbook mounted in the car so I use LogWorks as a virtual dashboard most of the time. I use the O-Meter as a simple/cheap way to watch AFR when the netbook is not in the car.
For details about the LC-1 look here:
http://www.innovatemotorsports.com/products/lc1.php
I also have a couple of SSI-4 boxes to monitor other sensor data. Not a bad data logging solution really.
Here's a picture of the screen:
Not a great photo but it's all I could find.
Jeff
Old Sep 5, 2011 | 02:48 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Mine's permanently installed under the boost gauge.
Old Dec 30, 2011 | 09:10 AM
whyaskwhy's Avatar
whyaskwhy
Jeff
So Is this the only one from innovate that I can run simulated narrow band to pcm http://www.innovatemotorsports.com/products/MTXL.php
This one you Can't ? because does not have 2 channels http://www.innovatemotorsports.com/products/db.php
Old Jan 1, 2012 | 09:23 PM
jsiddall's Avatar
jsiddall
Actually, it is the opposite. The LC-1 (which the MTX products do not use) has dual analog outputs in addition to the digital MTS serial datastream used for the MTS gauges (like the DB and G series gauges). Anything that includes the LC-1 to control the WBO2 sensor will allow a narrowband output.
Jeff
Old Jan 3, 2012 | 09:52 AM
383tpimachine
Jeff
My MTX-L has narrowband sim. I likely wont use it due to already having a bung in my passenger header and 85s only use one narrowband.
Need to install this sucker.
Old Jan 3, 2012 | 06:35 PM
whyaskwhy's Avatar
whyaskwhy
Hum funny Cuz my MTX-L I just bought does an its in the car running. Analog narrow band to pcm / Analog wide band band into Hp tuners an calibrated within in .1 ARF
From the manual that came with it ....
Connect the MTX-L to the computer and launch LM Programmer.
2. Select one of the Analog output tabs. The Analog output page looks like this:
Old Jan 3, 2012 | 10:24 PM
whyaskwhy's Avatar
whyaskwhy
OPS.... Quoted the wrong post LOL must be the 13.2 AFR was messing around with fuel adder charts .... in open loop
To Wideband O2 question
