MAP Sensor mount
Old Sep 4, 2011 | 08:03 PM
LD85's Avatar
LD85
Default MAP Sensor mount
I looked into the MAP sensor mounting spot today on Google, the HSR has port for a MAP sensor,, but there is no way under the sun to mount the MAP sensor higher than the vacuum port for the MAP.
I guess the best I can do is point the MAP sensor vacuum port downward
Old Sep 4, 2011 | 08:20 PM
stoydido's Avatar
stoydido
are you on the right forum? or am I?
Old Sep 4, 2011 | 08:42 PM
LD85's Avatar
LD85
i am,,,, you are not
Old Sep 4, 2011 | 09:42 PM
AKS Racing's Avatar
AKS Racing
Mine is mounted to the back of the intake and the vacuum (or pressure) is drawn from ~1" further down in the base of the manifold.
And the ESC signal to the FAST goes to the ESC box input.
Old Sep 4, 2011 | 10:10 PM
rodj's Avatar
rodj
Originally Posted by AKS Racing
Mine is mounted to the back of the intake.
I made a angle mounting bracket bolted to pass side of plenum with a line running to the vac port at rear
Old Sep 4, 2011 | 10:12 PM
LD85's Avatar
LD85
Thanks A !
I think I will put another port in the plenum so I can move the fitting lower.
Can I use a 10-32 brass barbed fitting or should I use a 1/8" NPT, my question I guess is,, does the fitting I.D. matter?
Old Sep 4, 2011 | 11:19 PM
AKS Racing's Avatar
AKS Racing
Thanks A !
I have fittings all hidden on the backside which is why you see plugs up on the plenum area. I like everything to be very neat and clean. No stray wires or hoses.
Either fitting should work. The key on mine is to ensure that I use nipples that have a sholder so that I can either use a hose clamp or a tiewrap to secure in place. 30 psi tends to find places to exit...
To MAP Sensor mount
