Camber Brace going in tonight or at least starting the project tonight. Any words of wisdom, tips, strategies before I tear into this thing. As soon as I finish my turkey samich I'm headin down stairs.
No beers in the fridge so my install time should be reasonable.
Sorry for the delay to those waiting with bated breath. The difference in over-all stiffness was surprising. I wasn't expecting it to be that noticable on a roadster. I noticed it the most during high speed turning/ lane changing and over -all tightness and front end quietness on rough road conditions.
What I considered the "wet noodle syndrome" is now tight as a gnats ***.
OK... What does this line mean???? :crazy:
You will shocked at how tight your coupe will be after putting the camber brace in. I couldn't believe how well it works with the targa top off. Try it, you'll like it. Other than new swaybars, this is one of the best mods I've done, esp for the money. BTW, Dave's customer service is the best. I called him three time while in the middle of the install. He was very patiant. Look out for the ECT sensor on LT1/4 motors. I ripped mine off and had to splice it.
Well....During cornering/turning my chasis would seem to turn before the body would. That is to say the body would have to catch up to chasis. (no, it's not the shocks-I just put on 4 new Bilstiens) It would roll around. That feeling is gone. I haven't put too many miles on her since the install but plan on playing with it quite a bit this weekend.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Re: Camber Brace going in tonight (silver & red CE)
[Modified by silver & red CE, 11:13 AM 5/2/2002]
Looks about time for me to pull my finger out and install that brace I have sitting in the garage...
MrNuke, It's not as easy on the 85 but still not bad you will have to remove the power steering pump pully so you can get the a arm bolt all the way out and relocate the power steering fluid reservior and the AC evaporator. But it was worth it I cant belive the differencne on the street I will be using it this weekend on the track for the first time. You might want to get an alignment after just to make sure.
Dave
:flag
