Headlights don't open?
Old Sep 5, 2011 | 09:52 AM
CAmaninacan's Avatar
CAmaninacan
Default Headlights don't open?
My headlights currently do not open, they are now staying open by using twist ties :yes nod: I cannot open it using the manual way either, so I'm thinking its the bushings. I need a suggestion on a good rebuild kit that contains bushings, gear, and the locking pin with two holes that you spread apart (the name escapes me). Thanks.
Old Sep 5, 2011 | 01:32 PM
STL94LT1's Avatar
STL94LT1
If the bushings are bad you will hear a noise when activated. Any sound?
Old Sep 5, 2011 | 01:54 PM
CAmaninacan
Yes it does, to me it sounds like the motors are spinning. But its just not rotating the lights.
Old Sep 6, 2011 | 11:49 AM
VetteMed's Avatar
VetteMed
That would be typical of failed bushings, could also be broken gears but bushings are far more common.
Old Sep 6, 2011 | 12:36 PM
aklim's Avatar
aklim
If it were me, I would get bushings and gears so that I do it once and be done with it. My gears looked OK but on closer inspection some time later, I found that there was a hairline fracture. Glad I have done it all
To Headlights don't open?
