ZR-1 Wheels?
Old Apr 30, 2002 | 09:32 PM
CMR250R's Avatar
CMR250R
Default ZR-1 Wheels?
I own a 1995 coupe, and I just bought crome zr-1 wheels for it. I was wondering if when I put them on do I need to get the low tire pressure sensors for inside the wheels? I was also interested in installing the mid america lowering kit- will this give me a problem if I run 285/40/17's on all four corners? Thanks in advance for the help. :chevy
Old Apr 30, 2002 | 11:31 PM
Voltech_LT4's Avatar
Voltech_LT4
Cruise-In IV Veteran
Default Re: ZR-1 Wheels? (CMR250R)
what size rims do you have? the 9.5's or 11 in the back?
Old May 1, 2002 | 10:10 PM
CMR250R's Avatar
CMR250R
Default Re: ZR-1 Wheels? (Voltech_LT4)
I got the 9.5's.
Old May 1, 2002 | 10:18 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
The 285s may scrub just a little on the front. 275/40 17s were factory on the 9.5 for Z07/Z51 cars.
[Modified by 93Polo, 9:32 PM 5/1/2002]
Old May 1, 2002 | 10:48 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
You should be able to use your stock ones, Make sure the tire tech knows about them. They are fragile and expensive. :cheers:
To ZR-1 Wheels?
