84 overheats
I have an 84 Corvette 4+3 that I purchased new that's been sitting in my garage for about 10 years and I've started getting it back into top shape.
I just installed a new 2 row aluminum radiator and a 160 degree thermostat. When I start it and let it idle, the thermostat opens at about 160 degrees and then the temperature just keeps rising until it turns on the electric fan at about 240 degrees. When I drive it down the freeway, it will cool down to about 190 degrees (the outside temperature is about 80). The oil temp is 195.
Any ideas of how I can keep the temperature close to 200 degrees instead of always rising to 240+ degrees? If I simply change the fan temperature switch to a 200 degree switch will I be fine?
Thanks in advance for your help.
I'm assuming you bleed the system?
Between cyl # 6 and #8 is a sensor in the head that tells the fan to turn on at a certain temperature. I've replace mine with one that turns the fan on at 195 degrees. Most times my temp runs 180- 210.
Manual fan switch
in 4 years, I can almost count on one hand the times my fans have come on. GM designed the system for good reasons.
if you are running that high there is another problem.
jc
I installed an all aluminum 2 row radiator myself this summer.
Before I was running about 220 all the time. Now I am at 190 when driving.
Yes it creeps up when sitting or idling but fans kick on at 228 for me.
When driving it runs at 188 to 190 on a 80' day.
It was running hot all the time before. I have a thermostat thats 185 so mine is right on
I dont think yours is a problem. I also own a 2011 Camaro and I have seen that run to 225.
These are all normal operating conditions.
Kevin
Also did you flush the cooling system before installing the new radiator? It's entirely possible that there is some corrosion in the cooling system that is not allowing a full flow of coolant. Did you install new radiator hoses? Could be that the lower hose is collapsing to where the flow of coolant is reduced. Is the water pump new? The impeller in the water pump could be corroded to where it won't push enough coolant through the system.
I also agree that there is no real reason to mess with the fan operation. The C4 cooling system is designed to run warmer to help with emissions. Seeing coolant temps of 195 to 215 or so is perfectly normal for a cooling system in good condition. The later C4's can run even hotter with temps in the 210-228 range before a secondary fan even turns on.
Once again, thanks for the inputs.
Bob
