Vibration From 50 MPH plus
Old Apr 30, 2002 | 10:53 PM
YellowC4's Avatar
YellowC4
Default Vibration From 50 MPH plus
I have A 1995 LT-1 6speed Today I went on the highway and I soon As i hit 50mph the car started To Shake like crazy and 80mph it turn in to Vibtration
I had Balanced and aligned the Car last month and I don't know what to check
Anybody knows what it could be Thanks
:confused: :confused: :confused:
Old Apr 30, 2002 | 11:06 PM
VetteNoob's Avatar
VetteNoob
Default Re: Vibration From 50 MPH plus (YellowC4)
Where do you feel the shake coming from? You could have lost a wheel weight, especially if it was a stick on type, it could have fallen off.
Old Apr 30, 2002 | 11:18 PM
YellowC4's Avatar
YellowC4
Default Re: Vibration From 50 MPH plus (VetteNoob)
Mostly form the back and I don't have the stick on type Iam going to have it balanced again
Old Apr 30, 2002 | 11:46 PM
vader86's Avatar
vader86
seems to be a common problem, mine shakes a little, but i think its more from the crappy roads in SC
Old Apr 30, 2002 | 11:50 PM
YellowC4's Avatar
YellowC4
Default Re: Vibration From 50 MPH plus (vader86)
one more thing Some days it shakes a little and other days the steering wobbles
Old Apr 30, 2002 | 11:54 PM
vader86's Avatar
vader86
could be anything from warped rotors to a wheel out of balance to wheel bearings to steering rack problems....long list on the last thread like this
run a search, its been on here before ALOT.
Old May 1, 2002 | 02:17 PM
maduraj's Avatar
maduraj
Mine used to shake like crazy too. I had new rims and new tires but that didn't help. I had the driveshaft balanced and u-joints replaced and that fixed most of the vibration. I was also getting a knocking sound from my steering wheel, and the dealer replaced the steering rack and the inner tie-rods and now the vibration is gone. Good luck.
Old May 1, 2002 | 02:40 PM
86VetteBill's Avatar
86VetteBill
Hope one of my old posts helps you out....
http://forums.corvetteforum.com/zerothread?id=275234
Old May 1, 2002 | 03:13 PM
Greg's '88's Avatar
Greg's '88
I feel your pain! My '88 has the exact same ailment. Everything I've done helped a little, but the vibration lives on. Now it is most pronounced at 80 MPH.
1) Replaced all 4 wheel bearing hubs ($700 for parts)
2) Four new tires installed and balanced ($700 for 275 ZR40-17 Futuras)
3) Drive shaft fully serviced: balanced, straightened, new Spicer U-joints ($160).
The vibration continues. :mad
I guess I'll replace all four rotors since they're original. I'll just keep throwing money at it until it stops doing it. :cry
Greg Sullivan
Old May 1, 2002 | 07:40 PM
YellowC4's Avatar
YellowC4
Default Re: Vibration From 50 MPH plus (Greg's '88)
I will Probably Change the U joints but how do I balance the Drive Shaft :confused: And Anything I hould be Aware Of when Changing The U joint it my First Time never done it Before
Thanks :flag
Old May 1, 2002 | 08:22 PM
Greg's '88's Avatar
Greg's '88
I didn't change the u-joints myself. I took the old drive shaft to a place that specializes in drive shafts and asked them to replace the u-joints, straighten the shaft (if necessary) and balance. They supposedly spin it on a machine at 3,300 RPM to verify balance. They kept my drive shaft for 24 hours and charged around $160. When I got it back, it looked brand new. Somehow they polished it to a high shine. :cheers:
If you are going to tackle the u-joints on your own you will need a press or a very strong vise to get the old u-joints out and the new ones in. A long time ago I bought some u-joints at Pep Boys (for a different car) and the mechanic did the swap. I already had the drive shaft out of the car.
Greg Sullivan
Old May 2, 2002 | 03:49 AM
Fletch54's Avatar
Fletch54
Thanks for the info guys. I also have a vibraition in my vette. Going to try the driveshaft. :rolleyes:
To Vibration From 50 MPH plus
