YSi on an LT1
Old Sep 6, 2011 | 06:22 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default YSi on an LT1
Thought you might want to check this out.
http://www.corvette-guru.com/modules...=15716&forum=1
Old Sep 6, 2011 | 08:04 PM
93Rubie's Avatar
93Rubie
Sounds nasty, I like it. Let there be Rock!!
Old Sep 6, 2011 | 08:06 PM
yedister's Avatar
yedister
I wonder if he can close the hood or if the hood was modified.
Old Sep 7, 2011 | 08:05 AM
BrianCunningham
Looks like it goes into the wheel well.
BTW
djxib wrote:
BrianCunningham wrote:
Sweet!
Details on the build?
Hi Brian,
It's a fully forged/built 383, front and rear internally balanced. LT1 bottom end, LT4 top end, extensively CNC'ed. The cam is 236/246 with a 115 LSA and 0.6" lift. 9:1 CR. On the engine dyno it made 430 crank horsepower and 400 ft-lbs tq.
Stage 3+ SPEC clutch, superdamper with 8 Rib pulley.
V7-YSi supercharger pulleyed for about 10-12 pounds (we'll see what happens!). 2-stage alcohol injection.
Going to be fun!
Andy
Old Sep 8, 2011 | 09:25 PM
383tpimachine's Avatar
383tpimachine
Vortech needs to make me a setup for the L98.
Old Sep 8, 2011 | 11:50 PM
qwiketz's Avatar
qwiketz
I'm not the only one anymore... lol.
I'm guessing the hood had to be notched. The ysi and volute of the ysi is pretty substantial.
Now I want a bigger cam. Mine sounds no where as aggressive as that! I believe that mine has a hot cam in it.
Old Sep 9, 2011 | 12:14 PM
BrianCunningham
any pics? Love to see it
Old Sep 9, 2011 | 12:21 PM
qwiketz's Avatar
qwiketz
sure. On youtube check "ysi c4 corvette" and it should pop up. I have a couple videos of the car idling on there.
Old Sep 9, 2011 | 02:13 PM
383tpimachine
Guessing this is it
http://www.youtube.com/watch?v=BNpmkIjf5gA
Old Sep 9, 2011 | 02:24 PM
qwiketz's Avatar
qwiketz
that would be the one. I'll get some new videos on there in the near future....
the one thing I don't like about our setups is the lack of space for a decent sized air filter. It's really tight there.
Old Sep 18, 2011 | 05:29 AM
Doughboy2k3's Avatar
Doughboy2k3
I have a V7 Ys trim I am going to be installing on the drivers side. I will be looking at around 15lb.
I have been searching around trying to find bearings and seals for it. Vortech is no help they want me to send it in and wont sell me the bearings. I will let you guys know how it turns out.
Old Sep 18, 2011 | 08:08 AM
PAINTER MAN's Avatar
PAINTER MAN
http://www.performancebearing.com/dragracing.html
This guy can build you bearings for anything you need. I bought bearings from him last year.
Old Sep 18, 2011 | 04:30 PM
qwiketz's Avatar
qwiketz
Check the corral. There much more info on this topic versus corvetteforum
Old Sep 20, 2011 | 11:16 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Default L98 YSi
Hi Guys !!! I've done several YSi's on the C4-L98 !!! greg
Old Sep 20, 2011 | 01:43 PM
qwiketz's Avatar
qwiketz
Greg, how much power and boost is typical of these setups?
Old Sep 20, 2011 | 01:49 PM
BrianCunningham
FYI Greg is the one helping out on the install I originally posted.
BTW Like the custom wheel well piece, nice finishing touch.
Old Sep 20, 2011 | 03:53 PM
Doughboy2k3
Thanks Painter Man. Quick five minute call and the bearings are on the way. Thanks Walt.
Old Sep 20, 2011 | 03:59 PM
Doughboy2k3
Hey Greg,
We have not spoke in a while. Hope everything is well.
I am going to call you in the up coming weeks I have been looking at the two stage water cooling systems you sell and have to pick one up.
Also do you sell just the 90 degree elbow shown above with the BOV?
Thanks, Walt
Old Sep 21, 2011 | 04:24 PM
djxib's Avatar
djxib
Brian thanks for posting my vid, I've been trying to find some time to post it. Most of you will have noticed that the YSi wasnt even hooked up; nothing quite like a big cam/ forged chevy 383 with open pipes!
Since the video was taken I have been quietly putting the final touches to the setup - I am currently in the early stages of tuning and so far street drivability is OK, I have some VE smoothing to do below about 3000. Hoping to hit the dyno next week for a couple of fairly easy pulls up to around 5000 to see how it's looking under boost.
The hood has been extensively notched, although I did some funky twists on the intake (and relocated the power steering reservoir) to prevent too much notching. The YSi is so big that it wont really fit on that side of the engine bay without the pipework extending into the wheel well. What you see in my avatar is 'phase 1' - I have enough clearance (I'm running coilovers so have lifted the car a little) for straight line track work and regular road use, but I would not take it to a road course in this configuration.
'phase 2' I am going to rotate the supercharger volute to point downwards and run the pipework down inside the wheel well and under the car. I'll need to run stock size wheels on the front (i.e. 245's) to make that work. It may allow me to run an air-air intercooler which could be fun.
Anyway - its been quite a project, looking forward to posting up some dyno results when its fully tuned.
To YSi on an LT1
