LS1 INTO 84 CROSSFIRE
Old May 1, 2002 | 03:56 AM
RIGHTHANDRIVE84's Avatar
RIGHTHANDRIVE84
Cruising
Default LS1 INTO 84 CROSSFIRE
GIDAY FROM DOWNUNDER FELLOW CORVETTE NUTS ;WONDERING IF ANYONE COULD HELP WITH A HEADS UP ON ANY PROBLEMS I CAN EXPECT DOING THIS SWAP I'LL BE USING A MOTEC COMPUTER AND RETAINING THE 4+3 :cheers:
Old May 1, 2002 | 04:20 AM
GlockLT4's Avatar
GlockLT4
Default Re: LS1 INTO 84 CROSSFIRE (RIGHTHANDRIVE84)
Not sure how to help ya, but I had to ask where you're from lol. Australia??
[Modified by Glock'94, 2:21 AM 5/1/2002]
Old May 1, 2002 | 04:49 AM
RIGHTHANDRIVE84
Cruising
Default Re: LS1 INTO 84 CROSSFIRE (Glock'94)
MY BLOODY OATH MATE .CAPITAL CITY OF AUSTRALIA ACTUALLY "CANBERRA" A.C.T :cheers:
Old May 1, 2002 | 08:15 AM
BrentDev's Avatar
BrentDev
First off - try hitting your CAPS LOCK key - (Its internet ettiquite that basically says you are YELLING!)
But - to answer your question, there is an 84 on here, that the person has yanked it out, put in a LS1, and installed stock Z06 wheels. It looks VERY sharp. I cannot for the life of me remember his name right now, but he's on here quite a bit. He should hop on here and post his name sometime. Hang tight!
:cheers:
Old May 1, 2002 | 08:50 AM
GiDvEtTe84's Avatar
GiDvEtTe84
Default Re: LS1 INTO 84 CROSSFIRE (BrentDev)
.......there is an 84 on here, that the person has yanked it out, put in a LS1. I cannot for the life of me remember his name right now.....
Me neither! :crazy:
Old May 1, 2002 | 12:13 PM
houseofspeed's Avatar
houseofspeed
That would be one of my partners....Trace Torrence (LS1C4, TracerX)....the car is a driver and he can point you in the right direction on the swap.
Old May 1, 2002 | 05:30 PM
Wheelman's Avatar
Wheelman
i for one want to see a pic of your right hand drive 84~!
Old May 3, 2002 | 02:08 AM
TracerX's Avatar
TracerX
You will need to fab up motor mount brackets, notch the top rear of crossmember for clearance, modify thermo housing, move a/c and alternator to top positions custom fuel rail with return line, swap valve covers, custom pulleys and brackets. I would use the F-body motor as you will need throttlebosdy that accepts a cable , oil pan and f-bod manifolds or shorties.
E-mail me with any specifics that you need and I will let you know what you can expect.
Good Luck
Trace
To LS1 INTO 84 CROSSFIRE
