Aluminum Wheel Oxidation
Old May 1, 2002 | 12:05 PM
mhorner23's Avatar
mhorner23
2nd Gear
Default Aluminum Wheel Oxidation
What's the best way to remove oxidation on my aluminum wheels on my '84? I've been advised that compound and buffing is not the best way.
Mike in Savannah
Old May 1, 2002 | 12:30 PM
vader86's Avatar
vader86
Default Re: Aluminum Wheel Oxidation (mhorner23)
you cant remove the oxide layer, you can buff and wax the thing to death to get excess off
Old May 1, 2002 | 12:56 PM
Mr. G.'s Avatar
Mr. G.
Mike,
If it's just the clear peeling you can strip and re-clear the wheels.
If the aluminum is oxidized (actually pitted) stripping, sanding, and buffing are your only solution.
Hope this helps.
Joe
To Aluminum Wheel Oxidation
