Optispark?
Old May 1, 2002 | 01:53 PM
97Supra's Avatar
97Supra
Default Optispark?
After trying to narrow down some problems with the car last night, I went to bed and forgot to close the hood. Woke up this morning and it was pouring rain. Now the car won't start. It turns over and acts like it wants to crank, but it won't. Is this a wet optispark? What do I do?
Thanks,
Jason
Old May 1, 2002 | 01:54 PM
scorp508's Avatar
scorp508
It may be! If you can put a heat lamp or other source of neat near the opti. Do not start the car. The real death of them comes if it is wet and you try to start/run it for while. Let it dry for 24 hours or so in some heat.
Old May 1, 2002 | 01:59 PM
97Supra's Avatar
97Supra
Default Re: (scorp508)
Thanks scorp. Wish I had known that before I just tryed to crank the **** out of it:)
See ya,
Jason
Old May 1, 2002 | 02:32 PM
97Supra's Avatar
97Supra
Default Re: Optispark? (97Supra)
I put a hair dryer and a heat lamp as close to the optispark as I could get, and after about 30 min. the car now starts, but runs very poor. I'm assuming this means that the opti is the problem. Now, do I start the car and take it on the highway to get some air moving through there or leave it sit like it is. I was supposed to be at work an hour ago:)
Thx.
Jason
Old May 1, 2002 | 03:08 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
You have the vented model so the moisture evaporate and get sucked out as the engine runs and heats up.
Old May 1, 2002 | 03:15 PM
97Supra's Avatar
97Supra
Default Re: Optispark? (AquaMetallic94LT1)
Thanks. Guess I gotta go to work now:)
Old May 1, 2002 | 03:39 PM
John Row's Avatar
John Row
You probably have wet plug and coil wires maybe 'puter connections. Let it dry.
It's a shame these are such wimpy cars around a little water.
With a 95 I wouldn't worry about the opti.
To get a warm fuzzy or may be a heart stopper, you could pull codes and see what the computer is complaining about (if anything).
To Optispark?
