421 dyno run!
Old Sep 15, 2011 | 06:00 PM
  #41
88BlackZ-51's Avatar
88BlackZ-51
Originally Posted by Corvette0096
Your only 28 HP under my 381 CID On E85.
Notbad for a power adder Richy!
I have a feeling a 100-150 shot will be suffice for the old girl.
Old Sep 15, 2011 | 06:40 PM
  #42
tequilaboy's Avatar
tequilaboy
Sounds pretty good Rich. What's your MAF flow at 462 RWHP?
Old Sep 15, 2011 | 06:55 PM
  #43
Corvette0096's Avatar
Corvette0096
That was just on the motor. On a mustang dyno that read low though a mushy 4000 stall.
Old Sep 15, 2011 | 08:22 PM
  #44
88BlackZ-51
Power adder meaning E85.
I dont use E85 so if you comparing our dyno numbers its not apples to apples.
Now go buy that C6 Z06 and be done with it.
Old Sep 15, 2011 | 10:24 PM
  #45
Corvette0096
Dude your blowing up my PM Box. Soon as I sell the Ferrari I will.
Old Sep 16, 2011 | 09:12 AM
  #46
5abivt's Avatar
5abivt
Just curious Rick . The c6z06 has been out for several years. We all know it has 427 ci. What are your thoughts on why it has a 260cc port volume?? That's a whopping 65 ccs more than yours.
GM must have issues.. I think they need to read up on forums or ask engine builders/head companies to learn about how much volume they need to use in their heads?
Old Sep 16, 2011 | 09:20 AM
  #47
cv67's Avatar
cv67
St. Jude Donor '05
Actually it is, as its just fuel.
Dont get so hung up on numbers/dyno sheets and cha$ing 5-10-20.
Time to get the ZF in there so you can track it.
If it went fast but only made 401rwhp its still good right!
Old Sep 16, 2011 | 10:22 AM
  #48
tpi 421 vette's Avatar
tpi 421 vette
You really can't compare port volume from a First gen engine to a LSX. They are apples to oranges apart. Different everything.
Old Sep 16, 2011 | 11:04 AM
  #49
TTOP350's Avatar
TTOP350
Not as diff as you would think.
But to me I look at the LS stuff as a updated pontiac motor. Lot of similarities. The biggest is they use same size block for all diff cube motors.
Makes you wonder Y old "big blocks 396 427 454s" had large port volumes. Cuz they need it.
most of the BBC AFR stuff is 265-385
I'm running 235s on my 4?? inch motor and wish I had the new 245s.
bigger heads and fuel inj are a perfect match!
Old Sep 16, 2011 | 11:23 AM
  #50
tpi 421 vette
LSX has a taller deck height gives it a little longer port adding port volume to it. And it's shape and valve angles are obviously totally different from ours.
And BBC's, part of the reason their port volumes are so big is the long port length.
Old Sep 16, 2011 | 11:30 AM
  #51
5abivt's Avatar
5abivt
I didn't mean anything towards ricks builder or head guy I was just stirring the pot a little.
What's got me interested is Rick is now searching for more power with exhaust and eliminators and other means and I feel like saying isn't this EXACTLY the motor he asked for? Eliminators will make the car louder and drone etc I am agreeing with others here to just make sure the tune is spot on and enjoy it!
Old Sep 16, 2011 | 01:37 PM
  #52
TTOP350's Avatar
TTOP350
SBC deck height 9.025 stock, Tall decks avalible
LSX deck height 9.25 stock, tall decks avalible
SBC valve angle 23deg stock, 18 15 14 10 even 4degs
LSX valve angle 15deg stock, performance LS is 12ish and better n aftrmarket
If you want to buy same valve angle heads as a LSX 4 your SBC you can. (Pontiac used 14deg valves in 1955-81)
The LS went back to a more standard port (likeSBC) because its makes more power and has more volume.
By port length Im guessing you mean cyl volume/deck height due 2 deck height.
It also has to do w the stroke of the crank(sounds dirty huh?)
short stroke means piston travel is reduced (less volume) compared to long stroke cranks.
I guess my point it a engine is a air pump, less restriction = more power no matter what the platform.
Old Sep 16, 2011 | 01:40 PM
  #53
navy_vette's Avatar
navy_vette
I've said it before and I'll say it again. There are quite a few things that we know here that GM never even dreamed about.
And what the heck is with the apples and oranges references in this thread? Someone needs to up their sucrose intake.
Old Sep 16, 2011 | 01:51 PM
  #54
88BlackZ-51
Actually the motor turned out almost exactly as planned, but I didnt expect the exhaust to be somewhat of a bottle neck.
This thing puts out 470rwtq and makes torque everywhere!!
After speaking to 85Vet, DDSLT5 (both with bigger cube motors) it is clear that my exhaust is a restriction, and I have to think it over whether I spend the big bucks on the 1 7/8 stepped headers, or so I just an x-pipe to replace that B&B reasonator, or eventually do both.
I could leave the car as it sits or spend some $$$ and gain imo another 15-25 rwhp.
Either way its a blast to drive, and it will even be quicker come spring with the 3.45's. What amazes me is how quick it is with 3.07's which is more or less a highway gear for the D44.
But heh, I went threw with the build, spent the money, and now I am driving it.
Changing some of the exhaust really isnt the end of the world.
Old Sep 16, 2011 | 06:46 PM
  #55
1989TransAm's Avatar
1989TransAm
"Changing some of the exhaust really isnt the end of the world"
I like the way you think.
Old Sep 16, 2011 | 07:19 PM
  #56
LD85's Avatar
LD85
Rick, don't bite, enjoy the car,, clear your head and go slow...
OR,,, throw money into the wind
:bluean gel:
Old Sep 17, 2011 | 08:37 PM
  #57
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Awesome!! Now get that b!tch to the track!
To 421 dyno run!
Old Sep 17, 2011 | 08:46 PM
  #58
Dr.Huxtable's Avatar
Dr.Huxtable
^ thats where these cars are meant to be!
Old Sep 17, 2011 | 09:14 PM
  #59
mistaben's Avatar
mistaben
those are awesome numbers, and your engine is sooooo clean too! i'm jealous of the cleanliness!
gjdm!.
Old Sep 17, 2011 | 10:53 PM
  #60
85vet's Avatar
85vet
Cruise-In V Veteran
Enjoy your new found cubic inches and hp - but save your $$$$ your are not done yet. This is truly a disease
