coilovers?
Old Sep 13, 2011 | 12:09 PM
sons*c4's Avatar
sons*c4
Default coilovers?
just out of curiosity what are the pros and cons of lowering and using coilovers on a C4?
i do auto-x with it and im not worried about scraping anywhere. but i am really looking for performance advantages.
Old Sep 13, 2011 | 12:18 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Well on the pro side, you can tune the suspension and corner weight the car eaisier.
On the con side:
Class bump, do you have enough HP and experience to compete in the class the coilovers will place you in
The suspension is adjustable - can you get enough test time to make it work. make a mistake and the handling can be lots worse.
Old Sep 13, 2011 | 03:05 PM
navy_vette's Avatar
navy_vette
On the con side:
Just go for an upgrade kit and keep the mono spring system. You can get better handling, and stay in the class. Plus, it's cheaper.
I know I have seen these kits all over the place. Lots of companies make this kind of kit.
The coilover kits DRASTICALLY improve handling performance. Combined with aftermarket adjustable sway bars, toe bars, control arms, on and on and on, and you can create a car that runs on rails. It'll make your car feel light as a feather.... along with your wallet...
Old Sep 13, 2011 | 07:56 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
What they said.
the biggest advantage is being able to stiffen it up as much as you want.
The downside is the class you run in.
I'll be in SCCA SSM (Super Street MOD), up against cars a 1,000lbs lighter.
Old Sep 13, 2011 | 11:38 PM
sons*c4's Avatar
sons*c4
will just replacing the monospring lower the car at all?
Old Sep 13, 2011 | 11:53 PM
Dr.Huxtable's Avatar
Dr.Huxtable
Longer bolts on the mono spring will lower it
Old Sep 14, 2011 | 02:19 PM
BrianCunningham
Vette Brakes sells a de-arched spring with a greater rate
That's what you want to stay in Street Prepared.
Old Sep 14, 2011 | 02:23 PM
navy_vette's Avatar
navy_vette
Longer bolts. If you look at your suspension you will see the stock bolts. It gives you a little bit of play right now. Remember, the farther toward the end of the bolt, the lower the car.
Oh, btw, speaking of SCCA, I lost my class manual and I can't find it online. Does anyone have a copy? Possibly a PDF or just a website? I'm asking here instead of opening a new thread because it's related here and I don't want to start a new thread for such an insignificant reason.
Old Sep 14, 2011 | 02:31 PM
sons*c4's Avatar
sons*c4
ok. well this gives me alot to think about. im running a stock motor and trans and for now stock suspension. b-stock is already me running with cars a few hundred pounds lighter but AWD. i gotta get this thing to keep the tail planted and the front from understeering. i know that first the lower center of gravity will help a ton.... brakes are on the way. and i'm trying to stay in the tire class.
To coilovers?
