96 Rearend Oil..???
Old May 1, 2002 | 04:04 PM
24power's Avatar
24power
Default 96 Rearend Oil..???
Gonna replace the oil in the rearend,,,,,How much does it hold ? And can I get most of it out with a siphon pump? Thanks!! :cheers:
Old May 1, 2002 | 07:04 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Re: 96 Rearend Oil..??? (24power)
The siphon pump will remove most of the oil. The unit holds 1.5 quarts approx. Get it heated up before you do it so any residual moisture gets mixed with the old lube.
