[Tear Down Update 10]: We've got Intake!!
Old May 1, 2002 | 08:42 PM
scorp508's Avatar
scorp508
Default [Tear Down Update 10]: We've got Intake!!
Heheheheh.... Ok today's list of dones.
1. Installed Comp Cam Pro Magnum Roller Rockers on Passenger Side & Adjusted All Rockers
2. Removed #7 Rockers in order to install forgotten washer on head bolt between them.
3. Installed Intake Manifold
4. Removed Cold Start Valve Provisions from Fuel Rail
For 65Z01 as requested, Fel-Pro 1204 Intake Gasket against manifold.
RTV Along front of block
RTV Along rear of block
Block with RTV
Gaskets in place w/RTV around water jackets.
Intake on and torqued down in sequence to 35 ft/lb in 5 steps of "snug", 20, 25, 30, 35 ft/lbs.
Test fitting the 2nd valve cover in place. Cleared rockers w/o a problem!
Old May 1, 2002 | 08:53 PM
LT5's Avatar
LT5
Default Re: [Tear Down Update 10]: We've got Intake!! (scorp508)
:cool:
Old May 1, 2002 | 08:54 PM
J Z06's Avatar
J Z06
OHhhh yes!!
Lookin' good! It'll soon be running and ripping up streets and tracks!!!!!! :cool: Nice
Old May 1, 2002 | 09:00 PM
scorp508's Avatar
scorp508
looks very fimaliar....make sure to retorque the head gaskets after the 1st heat cycle foe some peace of mind.
Even with the fel-pro perma-torques? I've also got ARP bolts & washers on it. Ok, that'll suck pulling all the rockers off again. :D :D Oh well.
Old May 1, 2002 | 09:06 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: (scorp508)
That looks great and the intake looks HUGE in the ports.
Btw does that intake have a rear water jacket crossover like the stockers do? Or is it blocked off?
Just wondering.Keep up the good work.
:cheers:
Old May 1, 2002 | 09:36 PM
65Z01's Avatar
65Z01
Scorp, you da man! Thanks much for those very informative pics.
Those 1204s aren's quite the same as the set that came with my FelPro TopEnd set. Mine have blockoffs over each rear water passage, as did the stock gasket. Vic'89 was just over and said that his 1204s were open back there too.
Anyway, it is interesting to see how you applied that RTV (I assume Black RTV), thanks again.
Old May 1, 2002 | 10:19 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: [Tear Down Update 10]: We've got Intake!! (65Z01)
very cool!! :cheers: :cool:
Old May 1, 2002 | 10:23 PM
Bender's Avatar
Bender
I don't think you will have to re-torque. I’ve been using them for years and never re-torque. I have disassembled motors that I put them on and all of the bolts were real tight, even after years of hard use.
Old May 1, 2002 | 10:27 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: (Quasar92Blue)
Same here.. I am running the Felpro 1010 gaskets.. no retorquing and no leaking
[Modified by -=Jeff=-, 8:07 AM 5/2/2002]
Old May 1, 2002 | 10:28 PM
dans86's Avatar
dans86
I really like those Valve Covers.... Nice Job Scorp
Old May 1, 2002 | 10:58 PM
Corvette0096's Avatar
Corvette0096
Hey, Did you leave all the water passages open?
Old May 1, 2002 | 11:04 PM
bogus's Avatar
bogus
Wow. You are getting there dude!!!!
Its looking like an engine again! :cheers:
weekend, eh?
get the tranny yet?
Old May 2, 2002 | 12:13 AM
John G 92's Avatar
John G 92
65Z01 I also have my Intake for my 87 and the block offs were on the back two water Jackets Scorp those middle ports are for the EGR valve. I don't think your suppose to block them off then the EGR valve is useless.
Old May 2, 2002 | 12:40 AM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
yeh.,...sure is coming along FAST.....Scorp.... good job!
hey...couple of quick questions...
what did all the engine and tranny mods set you back?
and you only rebuilt the top end right? does that hurt the bottom end?
thanks dude
ttyl
jeff
Old May 2, 2002 | 12:44 AM
vader86's Avatar
vader86
Default Re: [Tear Down Update 10]: We've got Intake!! (LT5FIRE)
:cool:
Old May 2, 2002 | 12:48 AM
6spd89's Avatar
6spd89
:cool: :cool: :cool: :cool: :cool:
Matt
Old May 2, 2002 | 12:53 AM
Blackout's Avatar
Blackout
Cruise-In I Veteran
Scorp dude.....you sure know your way around an engine man...all the more power to ya....cant wait to see her when you bring her down to BG.....good luck dude. :D :D
To [Tear Down Update 10]: We've got Intake!!
Old May 2, 2002 | 01:07 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
That is looking good!!!!
Come on, just lay the Superram on there and snap a pic! Gotta see what it's gonna look like when it's done!!!!
:D
Old May 2, 2002 | 01:08 AM
65Z01's Avatar
65Z01
Default Re: [Tear Down Update 10]: We've got Intake!! (John G 92)
John G 92, while I was discussing the water jacket blockoff issue with Vic'89 neither of us could figure out why it's sometimes blocked with only small "vent" holes (as is my set) and other times it's full open (as his and Scorp's sets). Hmm.
Also, the '87 Corvette intake base sitting on my desk has an EGR hole in the right side but the head is blocked on both sides.
The F-body LB9 with iron heads (and their L98 too) has the internal EGR passage from the heads. Whereas our L98s use the external pipe into the base. I just checked my '86 IROC and the intake base has no provision for external EGR entry.
Looks like FelPro may use the same gasket for all three applications, though that water passage issue is still a puzzle.
Old May 2, 2002 | 01:10 AM
scorp508's Avatar
scorp508
I would love to, but I can't. I held the runners up to the intake to make sure I had clearance with the intake bolts to install them. The engine is tipped back too far from no tranny so that the runners can't be held in place because of the wiper motor right now. I'll have to jack the engine back up level to install it and drop it down a little bit to put the tranny back. :)
