Royal Purple Synchromax?
Old Sep 16, 2011 | 03:29 PM
Mrmatt2009's Avatar
Mrmatt2009
Default Royal Purple Synchromax?
Okay so I have been searching this for quite a while now and never really found an answer. I just bought 3 qts of Royal Purple synchromax for my zf6. I have not put it in yet.
Can anyone tell me if this is good oil for the ZF6 or not? Thanks!
Old Sep 16, 2011 | 06:17 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Did you check with Royal Purple? They should be able to give you a yea or nay on using it. I just had my T-56 rebuilt and that is what they reccomend instead of Dex2.
Old Sep 16, 2011 | 07:25 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I know it says it is for manual transmissions. Now check this out. I used to buy that one for my DD and it was making noise and grinding on 4th gear, One day I visited RP website and found out that RP actually recommended 20W50 for my DD's transmission. I did it and all problems went away.
I checked for the Vette ZF Tranny and RP recommends 5W30 or XPR — Extreme Performance Racing 5W30.
http://royalpurple.com/transmission-chart-wu.html
Some people uses Synchromax and are happy with it. I just wanted to show you what they recommend.
Old Sep 16, 2011 | 07:26 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Only ONE WAY TO KNOW.
*Put it in.
*Run it ~3000 miles
*Drop it and take a clean sample
*Send the sample in for analysis.
*Review the results.
This was sone on the 3S forums and the results (in the Getrag trans) was unacceptable.
To Royal Purple Synchromax?
