service asr light !!!
Old Sep 17, 2011 | 04:54 PM
barney10mm's Avatar
barney10mm
Default service asr light !!!
the light is on and the car has a eratic , high ldle .after warm up..... plez help
Old Sep 17, 2011 | 04:59 PM
STL94LT1's Avatar
STL94LT1
Check your brake fluid.
Old Sep 17, 2011 | 05:02 PM
barney10mm's Avatar
barney10mm
i sucked most out and replaced ...........
Old Sep 17, 2011 | 05:39 PM
navy_vette's Avatar
navy_vette
No no no. Your going to have to do a full flush. From the top to the bottom. There is a specific pattern you are supposed to use. I don't know it off hand, but someone here will post soon what corners you are supposed to do in which order. And yes, it matters which order. Get a friend with a strong leg. He'll be pumping the brake for awhile.
Old Sep 17, 2011 | 06:10 PM
toptechx6's Avatar
toptechx6
See page two in the link to pull the codes, that will give you a starting point. Correct troubleshooting will require the Factory Service Manual.
http://www.corvetteactioncenter.com/...abs/index.html
To service asr light !!!
