Vibration problem
Old Sep 18, 2011 | 02:18 PM
kvnairborne's Avatar
kvnairborne
Default Vibration problem
Hello! I'm proud to say that I'm finally apart of the corvette world! I got a Black 1991 corvette after I got back from my deployment! Wanted one ever since I can remember. There's a slight vibration in the car and the guy I bought it from said it was the control arms. I have some money left over and thought I would go ahead and get a performance suspension system since I have to replace to control arms any ways. any suggestions would be helpful. I was hoping not to spend over 1500 for an all around system.
Old Sep 18, 2011 | 02:28 PM
navy_vette's Avatar
navy_vette
I would get the tires balanced too, just in case. You'll be surprised how many people screw that up.
Since you are military, I'm guess you have a hobby shop on base? The one here in Italy either lets you do it yourself, or you can watch/help the mechanic do it. They are the only place in Italy who can do my tires.
I've been looking at these kits from Mid America for awhile. It's just pretty far down on my list right now.
"Extreme" kit
http://www.mamotorworks.com/corvette...-148-3897.html
"Sport" kit
A bit over your 1500 bucks, but I'm sure you can swing it.
*edit*
OH, and WELCOME!!!
Tons of information and knowledge here. No one person can tell you what a forum post can tell you.
Old Sep 18, 2011 | 02:39 PM
leesvet's Avatar
leesvet
Congrats on the Vette !
....and Thank you for your service !
I'm sure you'll enjoy it as much as everybody else does...its love.
Regarding the suspension, you will get out MUCH cheaper if you simply get the Corvette suspension "right"...mostly bushings and joints. Ball joints, control arm bushings etc. IF needed.
On the rear, choose wisely on toe rod assy (critical for safety) and use poly bushings on the sway bars and control rods...not everywhere.
Change any bad hub assys, loose bearings make loose Corvettes, and you;re set.
Too many of these "kits" end up so harsh that the car becomes work to drive and thats when it quits being fun...
Bilstein shocks, some good springs frt & rear and you;re set. It'll never handle like it should without maintaining these basics...its a Corvette...it handles just fine, when its "right". Personally, I've never driven anything that was so forgiving and capable of correcting driver mistakes, like a good C4 Corvette will do...
Have fun !
Old Sep 18, 2011 | 03:28 PM
kvnairborne
Thanks for your help Navy the system is a little out of my price range but since I can do it myself I can afford the extra 300 bucks! That's a good thing about military posts they got everything you need to work on almost any vehicle.
Old Sep 18, 2011 | 03:32 PM
kvnairborne
Have fun !
Thank you for your help also I'm kinda **** about my vehicles so trust me when I say it will be done 100% right the first time and all the maintenance will be done 500 miles before the book says so. Your welcome for serving by the way I love the military and doing something that is helping the greatest nation in the world! I'll be posting pictures here in the next couple of weeks on the project!
Old Sep 18, 2011 | 04:56 PM
navy_vette's Avatar
navy_vette
Military attention to detail has been pounded so far into our heads that we will never get it back out.
leesvet is right about the kits though. They will make the Corvette a little far into the "rattle your skull" stage. But, if you live in an area that actually cares about the roads (not California) and repaves them at least once every 10 or 20 years (not California) then you should be able to handle it. The kit also recommends a lowering kit. It's just a longer bolt that is higher grade than the stock.
I don't have the kit myself, but I've been in a C4 with one. It does rattle the head a little, but it'll put your brain to the side of your skull around corners.
Old Sep 18, 2011 | 05:00 PM
383vett's Avatar
383vett
Congrats. Welcome to the club.
To Vibration problem
